Thread: Outer Tie Rod
Results 1 to 3 of 3
  1. #1 Outer Tie Rod
    Nov 2011
    Virginia
    So I am replacing the inner and outer tie rods on my 98 gtp. The drivers side went smooth but when I got to the passenger side, the outer tie rod bolt seems to be mushroomed and I can't get it out. I used the pickle fork method for the driver's side, just wondering if the puller will do the trick even though the bolt is mushroomed pretty bad. If the puller won't work, any suggestions on what I can do?
  2. #2 Re: Outer Tie Rod
    cut it off if nothing else.
  3. #3 Re: Outer Tie Rod
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i had to cut mine off no big deal when your replacing them anyways, just take a cut off wheel to them
  1. Bad outer tie rod end? Video link included
    By LoneGunman in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2011, 11:09 PM
  2. Outer Tie Rod Nut Siezed
    By zeppelin913 in forum Brakes/Suspension/Chassis
    Last Post: 08-08-2011, 04:58 PM
  3. Outer Tie Rods Write-Up
    By GAFF in forum Brakes/Suspension/Chassis
    Last Post: 10-01-2010, 11:59 PM
  4. wondering about outer tie rod
    By fremmy182 in forum General Tech Discussion
    Last Post: 09-18-2010, 02:30 PM
  5. Tie Rod Replacement Inner and Outer
    By mainecrab in forum Brakes/Suspension/Chassis
    Last Post: 07-09-2010, 10:31 PM
