Thread: Tranny help
Results 1 to 19 of 19
  1. #1 Tranny help
    huntington, wv
    Hello everyone. I have a 99gtp, The car runs great but the other day my tranny started slipping. Full of fluid and its not burnt. Next morning I go out and it just pulls great till it gets hot. Its showing a code but dont have a scanner, afraid to take it to be scanned. worried I woud break down or hurt the tranny farther. This just happened the other day, out of the blue started slipping.
    Like to get your thoughts on what it might be or do i just go and start pulling the tranny out.Is there any tips or tricks to changing tranny and how hard it is, it looks pretty hard. The car is un modded, thanks in advance for any tips or info on the problem.
  2. #2 Re: Tranny help
    Omaha, NE
    When is it slipping? From stop lights or while in motion?
    Does it slip in all gears or just 3 and D?
  3. #3 Re: Tranny help
    Grand Rapids, MI
    I would first go by a trans shop and get a free diagnosis (you want the code scanned). And provide us more details on what it's doing. Like Brian said, is it upon taking off, in gears, or during a shift??
  4. #4 Re: Tranny help
    huntington, wv
    It slips from stop and moving if i give it to much gas and I didnt check all the gears. I just was using drive and reverse. It slips in reverse too From a stop I didnt think it would ever get going. I was about 2 miles from my home and thought id try to limp it home. It was so bad I didnt think it would make it home. I first noticed it when i tried to pass a guy and it revved but didnt go. But when its cold it dont slip at all till it warms up a bit.
  5. #5 Re: Tranny help
    Omaha, NE
    Sounds like the forward band is going out.
    Click this link:Triple Edge Performance - Home Page
    The 5th option from the top lists the most common 4t65E problems, see if that helps you diagnose it.
  6. #6 Re: Tranny help
    Grand Rapids, MI
    When I mentioned forward band, Bill says this http://www.grandprixforums.net/could...tml#post796959
    cause it's etiher broken, working or cooked beyond black
    so i'm back to input piston seal theory that Dave has said.
  7. #7 Re: Tranny help
    huntington, wv
    Thanks for the link, I really couldnt tell alot from what was there. I just wonder why its great while cold then it gets worse .
  8. #8 Re: Tranny help
    Grand Rapids, MI
    The link was more for Brian because an experienced individual said that the forward band either works or it doesn't.
    But check out 4T65E Common Problems for common problems.
  9. #9 Re: Tranny help
    Omaha, NE
    Quote Originally Posted by drydd View Post
    Thats usually a sign of a fluid pressure issue. Fluid thins out as it gets warm.
    When is the last time it got a trand fluid and filter change?
  10. #10 Re: Tranny help
    huntington, wv
    I havent had the car very long and it has set awhile after I bought it. But I havent ever done i tfluid and filter. It has 165k and i have no idea if its ever been done.
  11. #11 Re: Tranny help
    Omaha, NE
    Honestly, I would try that before replacing the hard parts. 2 bottles of fluid, a filter and gasket all cost $50 at autozone. I think it might help you out here, and it can't hurt anything.
    Drop the pan, clean the magnet, pull the filter, then put it all back together and fill it up. I did mine a couple weeks ago in my 05 and I think it took 2-3 hours total.
    Whatever you do, don't flush the fluid, it can cause more harm than good.
  12. #12 Re: Tranny help
    Grand Rapids, MI
    yeah. a pan drop (fluid and filter and lucas) helped me quite a bit with my weird problems. But if you have something internally wrong, then only a rebuild will fix it. I suggest doing a pan drop and seeing how it goes, and of course getting a free diagnosis and finding what code it's throwing you. There are some common codes that will give us a clue to such problems as a PCS (pressure control solenoid) etc
    you will need 7-8 quarts of fluid, so buy 2 gallons of dex iii. and REUSE THE STOCK GASKET!!
  13. #13 Re: Tranny help
    Omaha, NE
    Quote Originally Posted by brandonl2000 View Post
    I disagree with this, the gaskets that come with the filter work just fine.
  14. #14 Re: Tranny help
    huntington, wv
    I was thinking that when it first hapened. I was suprised when it happened just up out of nowhere..
  15. #15 Re: Tranny help
    Grand Rapids, MI
    it may work fine...but have you compared the stock gasket with the new one? stock is strong and thick, the new one is cheap thin and flemsy.
    again, Bill and many others will advise you to re-use stock gasket as well. i have re-used mine 3 times now. the gasket is much more superior than the others. it doesn't make sense to use a lower quality gasket.
  16. #16 Re: Tranny help
    huntington, wv
    It had a whine/whistle when it was in gear and never went away as i sped up but it nver increased either. this started just a couple days before it started slipping
  17. #17 Re: Tranny help
    Just do a filter and fluid change with a bottle of lucas stop slip and see if it helps. Takes less than an hour and couldn't hurt anything.
  18. #18 Re: Tranny help
    huntington, wv
    Thanks for all the help guys i am going to do the filter and fluid and try the lucas as well. Thanks again for all the help.
  19. #19 Re: Tranny help
    Little late to the party. Some of the stuff you describe sounds a bit like a filter is a wise choice. The whistle/whine may be the pump starving for fluid. If that's the case it could explain the slippage. The slipping after warming up does sound like seals, maybe not though.
    I do recommend reusing the stock gasket if it looks good. GM designed it to be a lifetime gasket that gets reused. The cheap rubber/cork one that comes with the filter kit will work, but it's not the same quality as the factory one with the ribs etc.
  1. 3.1 tranny on a 3.8?
    By vinny of destruction in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2011, 11:18 AM
  2. 03 tranny
    By 03 grandprix in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-02-2011, 01:25 PM
  3. Non HD tranny into GTP?
    By Lawngoose in forum General Tech Discussion
    Last Post: 10-01-2009, 07:19 PM
  4. FWD 3.8l to RWD tranny
    By static2489 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-13-2008, 02:26 PM
