Thread: Installing HID fog lights questions
Results 1 to 14 of 14
  1. #1 Installing HID fog lights questions
    GT Level Member Haulero's Avatar
    Gray Court, South Carolina. USA
    Guys, have you install HID conversion kit on your foglights? my concern is: is safe to install HID bulbs using the same OEM housing? I'm just afraid that they gonna be a little hot and may burn/melt the housing. The other question is, my keyless system (aftermarket) make my foglights to flash when I lock/unlock my car. Is it gonna hurt my HID lights if they flash like that? Thank you for your help
    Note: I installed regular fog light bulbs before and they melted the housing for some reason, when I installed them they burned my fuse, someone told me to put a different fuse and that was a big mistake cause it didn't burn my fuse anymore, my lights stayed on but they melted my fog light housing lol thats why I'm now kinda scared.
  2. #2 Re: Installing HID fog lights questions
    Florida
    I ran 35w 5000k HIDS in mine for close to a year, and never had any problem with melting/warping.
    They did blow a fuse once, but I replaced it with the exact same size fuse, and never had a problem.
    Also, I always had my fogs on, so they flashed when i locked/unlocked the car...never had a problem...
    Just buy a good set of HID's, and you'll be fine.
  3. #3 Re: Installing HID fog lights questions
    Thank you for your help that make me feel safer Also, you said you ran this for almost a year. So what do you have now? did you install better fog lights?
  4. #4 Re: Installing HID fog lights questions
    i got 35w 10k in my fogs and havent had anyproblems with them, and i dont use my keyless anymore because i dont want them to flash, but i know theres a way to make it so they flash but i havent tryed do it
    SMGPFC Member #10
  5. #5 Re: Installing HID fog lights questions
    I might stop my foglights from flashing when lock/unlocking by turning off the foglight switch, if the switch stays on all the time, my foglights will flash, so if I don't want them to flash I just turn the switch off. I was just concerned that quick flashing may hurt the bulb life of the ballast
  6. #6 Re: Installing HID fog lights questions
    yea that'll work,,, but not for me i got hids in my lows to, so if i want to use my keyless i have to put my parking brake on all the time
    SMGPFC Member #10
  7. #7 Re: Installing HID fog lights questions
    Ocala, FL
    You can just turn the flash off when using it, that's what I did.
  8. #8 Re: Installing HID fog lights questions
    how?
    SMGPFC Member #10
  9. #9 Re: Installing HID fog lights questions
    Florida
    *in answer to the question directed at me*
    Car blew up for the 3rd time, said **** it and moved onto bigger and better things.
  10. #10 Re: Installing HID fog lights questions
    Apr 2012
    Wyoming, MI
    ClubGP Message Forum troubleshooting
    This shows you how to rewire your car's lock/unlock to flash the parking lights instead of the headlights. Just did it today, and it worked perfectly. Note that the fogs will still flash unless you turn the switch off. That is because your fogs work with your parking lights too.
    Ohio
    First thing... You just kicked a dead horse.
    Second thing... These are 97-03 not 04-06 cars. The fog lights do not flash
  12. #12 Re: Installing HID fog lights questions
    Apr 2012
    Wyoming, MI
    In my 2000 GTP, my fogs flash if the switch is turned on.
    Ohio
    Really? Hmm I guess it all depends on your system programming
  14. #14 Re: Installing HID fog lights questions
    Apr 2012
    Wyoming, MI
    Stock :/
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Need advice on installing blazertech 2200 fog lights.
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 05-27-2011, 11:37 AM
  3. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  4. advice on installing third set of lights
    By mhoran89 in forum Visual/Body Modifications
    Last Post: 06-28-2009, 04:24 PM
  5. Motor questions, installing a supercharger
    By dirtracer007 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-06-2008, 04:37 PM
