Thread: Traction Off and ABS Light
Results 1 to 3 of 3
  1. #1 Traction Off and ABS Light
    May 2012
    Ohio
    It has been about 2 years since my ABS and Traction control light first came on. In that time, I have had all my wheel bearings and my ABS pump replaced. Some wheel bearings have been replaced multiple times, and the ABS pump did not fix the problem either time, I just got tired of bringing it back to the dealership and shelling out money.
    So, as a pizza delivery driver, i drive in all conditions with lots of stop and go, so braking is very important, as is the traction.
    My ABS light actually burned out recently, but the trac off light is still displayed.
    Anyway, my official question is - Now what? Should i keep replacing the ABS pump? I had a guy tell me it might be the ECM, any thoughts there? I have seen a lot of threads similar to this one, but never really see any solid answers.
    And as a follow-up, any suggestion you may give or offer, can you let me know if it is a diy project for a "slightly more than a beginner" or if it is a bring it to the shop job?
    Thanks so much
    matt out
  2. #2 Re: Traction Off and ABS Light
    I'd check over wires to. Like from the WB to the main harness, its pretty easy for the old wires to become brittle and break or fray
  3. #3 Re: Traction Off and ABS Light
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    i had this same problem with my old 01 GT, i brought it to the dealer and they said it was wires ^ just like he said
  1. ABS and Traction Control Light on.
    By midrange in forum General Tech Discussion
    Last Post: 02-18-2012, 08:20 AM
  2. Traction control light and abs light on
    By Torri040 in forum Brakes/Suspension/Chassis
    Last Post: 09-02-2011, 04:03 PM
  3. ABS Traction Off Light
    By Phrozen99 in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 08:17 PM
  4. ABS and Traction light
    By nanuke in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2009, 01:19 PM
  5. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
