Thread: This welder do what I'm looking for?
Results 1 to 20 of 27
  1. #1 This welder do what I'm looking for?
    Florida
    It's a harbor freight Chicago Electric brand
    170 Amp MIG/Flux Wire Welder
    I need to weld in a 3" high flow cat and make a bung for the o2. There are some odds and ends I need to do on my truck as well. I can't afford anything much more than this, so I question you more experienced if you think it's worth it. I've been told I need to get something that has gas, and this says it has hookups. Do I need to use gas for exhaust work like this?
  2. #2 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    I use the flux core wire (0.035"). The welds look like poop but who cares...strong enough for an exhaust system.
    Yea that MIG will work fine.
  3. #3 Re: This welder do what I'm looking for?
    Wouldn't having a shop be lower cost?
    I'm not saying don't get it. I found a nice Lincoln on Craigslist and I'm starting to get decent at it. But it takes a bit of practice to get there.
    BTW, I saw that welder said 240V input.
  4. #4 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    It's a monster!
  5. #5 Re: This welder do what I'm looking for?
    I toss that out because most folks don't ahve 220V line in their garage. It kinda sucks doing work on the ground by the basement window where the dryer is located.
  6. #6 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    LOL
  7. #7 Re: This welder do what I'm looking for?
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    No you don't need gas, it's flux core! Yes that will be suffcient!
    4 out of 3 people have trouble with fractions
  8. #8 Re: This welder do what I'm looking for?
    Saratoga NY
    The cheaper 90 amp 100 dollar jobber will work on exhaust also. Itll plug in and work from an extension cord as well.
    If spending a few hundred whats another hundred to buy a quality machine that will last you your lifetime?
    Using flux will piss you off with leaks and ****ty looking welds.
    Thats all the 100 dollar one will ever do, atleast the 170 amper says you can add gas.
    Buy a used name brand setup, buy one without gas for now and save the money to be able to lay clean welds if the need arises.
    I can tell you I love my Hobart i bought new. Doing dozens of exhaust mods and other odds and ends has paid for itself many times over.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
    Florida
    I have sufficient access to a 220v to use it for what I want. I thought about just having a shop do it but I'm a do it yourself kind of guy and I'll value it more if I do it. I welded in high school with stick welders about 13 years ago but everyone tells me those are dinosaurs now, so I have to get up to speed. That one I linked seems like a good middle of the road to get back in with and still be able to accomplish what I want to do.
    Sent from my SCH-I405 using Tapatalk 2
  10. #10 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    IDK man. Stick welding is a viable, cheap option for welding anything over 1/2". Some of the newer ones will weld smaller stuff.
    I love TIG but completely suck at it.
    The MIG is the way to go for us amateurs. Once you get the right feed and voltage you can fly.
  11. #11 Re: This welder do what I'm looking for?
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    This would be a nice garage welder...but that is it. t. , this welder is good for what you are doing with your exhaust. Me personally, I would stick weld the exhaust. And I disagree with up to 1/4 material. The general rule of thiumb is 1 amp for every one thousands of material (1/4"=.250" so 250 amps) at least for a good penetrating weld. 220V input is the way to go. I suggest a 10lbs spool of er70s-6 wire, but you will also need a bottle of 75/25 for a shielding gas. I wouldn't go the flux core route.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  12. #12 Re: This welder do what I'm looking for?
    Jul 2011
    Michigan
    That was a general rule of thumb by the way. You can do 1/4" with a bit of prep work with 170 amps
  13. #13 Re: This welder do what I'm looking for?
    GT Level Member papaspanky's Avatar
    Jul 2010
    new england
    ok heres my .02 that welder will do everything you need to do and more. I have the 120 amp model and it works well (I used to weld for a living) you can make flux core look ok with a lot of practice but it rots out quicker. weld with gas its cleaner looks better and will not smoke you out as quick. (I use flux core for junk welding) make sure you have the propper wire and gas for what you are welding(Harbor Freight does not know what you need) find a welding supply shop locally and let them know what you are doing they will be able to get you the right stuff. dont bother with the 20 cubic foot bottle they sell you will only get about 45 or so minutes of welding out of the bottle once again welding supply place. I have 60 Cubic foot bottles its the minimum I would use. and finally buy a welding instruction book and lots of scrap and practice lots with machine settings etc(being able to properly set the machine up is almost half the battle). once again just my .02
    81 T/A pure Pontiac 350,700r4 3.23's coming soon pure Pontiac 462 06 gt wizaird,XS power Headers,zzp ss ic,overkill tune 180 stat autolite 104's, 3.6 pulley.Special Edition HORNY DRIVER mod.
  14. #14 Re: This welder do what I'm looking for?
    Jul 2010
    new england
    O B T W using the right wire, amperage and burnoff you can weld sheetmetal with stick.
  15. #15 Re: This welder do what I'm looking for?
    Jul 2011
    Michigan
    exactly what did you do as a welder?
  16. #16 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by papaspanky View Post
    Great advice. If you did this for a living then your opinion is worth more than 2 cents dude.
  17. #17 Re: This welder do what I'm looking for?
    Jul 2010
    new england
    I build Nuclear Submarines.I 'm not sure what book you read but in the real world 250 amps for 1/4" material is dpuble what you need so I hope you can run fast.I always thought 70s-6 came in a 12 lb spool at least where I work it does.
  18. #18 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    Hmm. ALARA
    My nuclear buddy.
  19. #19 Re: This welder do what I'm looking for?
    Florida
    So yes to the welder choice, no to getting the wire/gas from harbor freight, correct?
  20. #20 Re: This welder do what I'm looking for?
    Apr 2009
    Fort Worth TX
    The only flux core wire I'll use is Lincoln Electric. It's cheap, readily available and seems to work better than the other brands.
