Thread: Driver's side outside door handle broke
Results 1 to 7 of 7
jokyfo Driver's side outside door... 07-26-2010, 07:27 PM
TheOtherNick Re: Driver's side outside... 07-27-2010, 06:48 PM
iroc2 Re: Driver's side outside... 07-28-2010, 08:47 AM
1994grandprix Re: Driver's side outside... 03-02-2011, 09:03 PM
RockPilot Re: Driver's side outside... 05-06-2012, 10:20 AM
dsmuts Re: Driver's side outside... 05-06-2012, 10:24 AM
GTLGDP Re: Driver's side outside... 05-06-2012, 11:10 AM
  1. #1 Driver's side outside door handle broke
    Mesa, Arizona
    1994 Grand Prix 3.1
    Drivers door will open from inside but handle does not work on outside.
    How much does the part cost, anyone know?
  2. #2 Re: Driver's side outside door handle broke
    Charles City, IA
    Take the door panel off on the inside and hook the rod back up, or if the handle is actually broke go to a junk yard.
    SMGPFC Two Nipple General
  3. #3 Re: Driver's side outside door handle broke
    Donating Users iroc2's Avatar
    Jul 2010
    Lansing IL
    i replaced my outside door handle. it was broken and i got the last one from my local junkyard. very common problem. then i just got done tightening it all up. if you handle isnt broken, youll notice that the rod that is connected to the handle is threaded at the end. take the rod off at the handle by removinfg the clip and then turn the nut and that should fix it. for the outside door handle you do not need to remove the interior door panel. just the pannel that is directly behind the outside door handle.
    SMGPFC # 008 -White 1995 Grand Prix SE: tinted tails, Flowmaster 40 Series mufflers with resonating tips. much more to come eventually
    Quote Originally Posted by Xorbex View Post
    I almost beat the man but murphy showed up.
  4. #4 Re: Driver's side outside door handle broke
    US
    is there a way to open the door when both handles are broke of
  5. #5 Re: Driver's side outside door handle broke
    Apr 2012
    Idaho
    My handle just broke off on the outside. I'm looking down into the door trying to figure out how to get it open. I cannot get into the passenger side as it is locked and I do not have a door key or keyless entry.
    Any advice on how to get in, without a brick, would be greatly appreciated. Thanks in advance.
  6. #6 Re: Driver's side outside door handle broke
    See if you can get a cop or locksmith to get it open with a slim jim
  7. #7 Re: Driver's side outside door handle broke
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    On my 2000 gtp it seems like my drivers door handle is loose and could possibly break. Does this require taking the door panel off or no?
  1. Driver door up, driver side unlock and power mirrors are out!!! Help
    By Dangerous313KidInAPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-25-2009, 12:12 PM
  2. Driver's side door key
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-20-2009, 03:01 AM
