Thread: Hid help needed
Results 1 to 7 of 7
  1. #1 Hid help needed
    Iowa
    I just got my HIDs back from WBS for a warranty replacement. And they are doing the same exact thign my old set did, leading me to believe its something with my
    car
    Keep in mind it does this WITH and WITHOUT the relay harness installed..
    When i first turn them on the pass side will flash and go out, but the drivers side works perfect. Then when i shut them off and turn back on they both work perfect. Let the car sit for a bit and the pass side will not work again, drivers side still works. I know for a fact its not the ground as I am using a body ground and get almost no resistance according to my multimeter. I have already tried switching the ballast and bulbs as well and the problems stays on the pass side....
    Leading me to think its a problem with the cars wiring somewhere...
    Anybody ever experienced this or have any idea whats up?
    Eric
  2. #2 Re: Hid help needed
    May 2008
    Winnipeg, MB
    same thing is happening to me right now
    2007 Pontiac Grand Prix
  3. #3 Re: Hid help needed
    try putting a regular bulb back in and see if it still does it,
    what was replaced all of the kit?
    SMGPFC Member #10
  4. #4 Re: Hid help needed
    May 2008
    Winnipeg, MB
    nevermind, I figured out the battery was too low to run both HID's, started the car and they both work
  5. #5 Re: Hid help needed
    Mine only work right if the engines running.
    They all do that
    SMGPFC Member #10
  6. #6 Re: Hid help needed
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    mine work fine without the engine running, headlights and foglights. VVME FTW
  7. #7 Re: Hid help needed
    GT Level Member mkyota1's Avatar
    Daytona, florida
    I was fighting with my hid's for a while with the same problem. Even though I was using a relay harness wires were too thin. I ran new wires on the high amp sides of the relay and now they work great if the car is running or not.
  1. 400+hp Needed
    By crzystve42 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-11-2012, 07:49 PM
  2. 98 pcm pin out needed
    By jenkins6586 in forum General Tech Discussion
    Last Post: 03-16-2011, 06:39 PM
  3. CD player instal, parts needed, advice needed
    By timmaayy2323 in forum Audio, Security & Visual Electronics
    Last Post: 02-21-2011, 08:53 PM
  4. Please help needed
    By chi_town in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-24-2009, 04:09 PM
