Thread: Warm Air Intake
Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21 Re: Warm Air Intake
    GXP Level Member Kolton Lock's Avatar
    Mar 2012
    Minneapolis MN
    i adjusted the grommet on the MAF sensor holder thingy..
    it stopped whistling for a little bit! so think it's just a leak?
  2. #22 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    Points, In theory it should work. i'm not entirely sure of this. as i'm new to the grand prix scene, but i have found about 99% of the parts are interchangeable through Series 2 and 3
  3. #23 Re: Warm Air Intake
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Ok thanks, What didnt match up? and did you have to take the transmission from the 07?
  4. #24 Re: Warm Air Intake
    Ohio
    when the tb plate is partially open, the whistle is air going around it...
    manually put it in 2nd around 30-35 and climb to 3k with the cutout open or closed and you hear that whistle.....makes me drool lol especially around this one curve on the highway next to the concrete divider where the sound bounces off of it...i love it
  5. #25 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    As far as i was aware, the plastic cover, the intake manifold were the only things that didnt fit. but that's all the previous owner told me. I believe the transmissions are the same from 97 to current
  6. #26 Re: Warm Air Intake
    Ohio
    no...97 and 03 are different from 98-02 gt wise.
    03 is different from 97-02 gtp wise
    04-05 comp g is way different than 04+ gtp and gt(supercharged)
    04+ could have different gear ratios than others..
    best for you to stick to the gt reference up above.
  7. #27 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    well like i said, i just listened to what the dude i bought it from said about it lol
  8. #28 Re: Warm Air Intake
    Nov 2010
    Alright, Thanks for the info
  9. #29 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    yeah dude sorry i couldnt give you all the info. the search bar at the top is definitely your friend dude
  10. #30 Re: Warm Air Intake
    Mar 2012
    Minneapolis MN
    So after prenty of sealing and tweaking. the whistle is still there... but now it sounds like i have a turbo in the car lol
  11. #31 Re: Warm Air Intake
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    or just go turbo
  12. #32 Re: Warm Air Intake
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    like i said, whistling wont go away
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
    Mar 2012
    Minneapolis MN
    I would go turbo if I have 2 grand, or I would whipple supercharge if I had 3 grand
  14. #34 Re: Warm Air Intake
    Mar 2012
    michigan
    series 2 ands series 3 heads lim and uim are diff blocks are the same
    Mar 2012
    Minneapolis MN
    Yep I do have different heads.
  1. Issue when car is warm
    By mrfreez in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-11-2011, 05:40 PM
  2. Warm stalling
    By Jaybird in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-03-2011, 04:49 AM
  3. warm up
    By grand2000prixgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 09:19 PM
  4. Any way to quiet down an intake during the "warm up" stage?
    By nickbuol in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 01:37 PM
  5. Rough on warm start
    By hacket in forum General Tech Discussion
    Last Post: 03-22-2009, 12:01 PM
