Thread: Rpms drop under slow acceleration at 45mph
Results 1 to 12 of 12
  1. #1 Rpms drop under slow acceleration at 45mph
    Dec 2010
    DMV
    Ok lately I've been having my rpms drop at 45-50 Mphs. Usually happens under slow acceleration. If I punch it it'll shift fine and shows no issues. Any ideas? I was thinking cat but that was just replaced 3 days ago. Trans was rebuilt maybe a month and a half ago. Also, what's the vacuum reading at idle. Mines was saying 15.9. I'm thinking that's wrong. Thanks guys
  2. #2 Re: Rpms drop under slow acceleration at 45mph
    Thats alittle high at idea, usually its like 13-14
    Over drive kicks in around that speed and drops the rpm down like 3-400. If thats what your talking about
    SMGPFC Member #10
    Dec 2010
    DMV
    Ok that's what I just read about the overdrive. Thanks. What can I do about the vacuum reading
  4. #4 Re: Rpms drop under slow acceleration at 45mph
    Got to go hunting, take a can of carb cleaner, start car, spray lines and hoses with the carb cleaner(not all at once spray in small areas) when you hear the engine rpms go up in youve sprayed over the leak, then start zeroing in on the leak
    SMGPFC Member #10
  5. #5 Re: Rpms drop under slow acceleration at 45mph
    huh?
    Vacuum at Idle should be ATLEAST -19. My car runs at -20.3 all day long at idle.
    If your only at 15ish you have a vac leak.
  6. #6 Re: Rpms drop under slow acceleration at 45mph
    Maybe i thinking about na motors, idk if a boosted motor is different
    SMGPFC Member #10
    Dec 2010
    DMV
    Ok so try the carb cleaner trick
    To find the leak. I was thinking it should be at 20 but wasnt sure
  8. #8 Re: Rpms drop under slow acceleration at 45mph
    Nope, should both be around the same.
    Dec 2010
    DMV
    Any particular place to look for a leak?
  10. #10 Re: Rpms drop under slow acceleration at 45mph
    The engine bay...lol
    SMGPFC Member #10
  11. #11 Re: Rpms drop under slow acceleration at 45mph
    Vac tree.
    Any of those lines.
    Any of the T's or connections on the line from the FPR to the LIM to MAP.
    Gasket leaks, if you ever taken the blower or TB off.
    EVAP hose to TB.
    Follow any vacuum line.
    Dec 2010
    DMV
    Alright will check first thing in the morning. Thanks. I'll post back with results.
  1. shaky acceleration and rpms goin crazy?
    By jmendujano in forum Introductions/Noob Questions
    Last Post: 10-12-2010, 07:16 PM
  2. RPMs...??
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 11:47 PM
  3. Slow Acceleration 3800 Series III in Fiero
    By D2inDFW in forum PCM Tuning
    Last Post: 03-27-2009, 11:37 PM
  4. 98 grand prix slow acceleration
    By jeffster in forum General Tech Discussion
    Last Post: 03-27-2009, 05:15 AM
  5. Loud noise above 45mph
    By zofsharick@gmail.com in forum General Tech Discussion
    Last Post: 11-09-2008, 10:03 PM
