Thread: Blend door acuator , 2 ,one on each side of the dash, correct part #?
Results 1 to 6 of 6
  1. #1 Blend door acuator , 2 ,one on each side of the dash, correct part #?
    SE Level Member fhaines's Avatar
    Apr 2012
    Lebanon, Ohio
    Hi,
    I checked the passenger side and it wont move, always on cold. I removed it and moved the blend door by hand, it is free. Car had the digital dual climate control.
    So im going to replace the passenger actuator. Is this the correct part#?
    DORMAN Part # 604106 {#89018365} Temperature/Recirculation Actuator
    Controls A/C Blend Door; Temperature; w/Automatic AC Controls
    Thanks,
    Fhaines
    2000 Grand Prix GT Metallic Green 4 Door
  2. #2 Re: Blend door acuator , 2 ,one on each side of the dash, correct part #?
    You do realize, we'd be looking it up just like you did?
  3. #3 Re: Blend door acuator , 2 ,one on each side of the dash, correct part #?
    the part # is on the actuator, (sticker) and from my own dealings with it, the # has changed a few times, and they do cross over. your lucky, the pass side is the easy one to get to.
    my regal has 2 part #'s that should work, the old # and the new #.
  4. #4 Re: Blend door acuator , 2 ,one on each side of the dash, correct part #?
    GTP Level Member
    springfield IL
    Are they the same for the digital climate controls unit...???
  5. #5 Re: Blend door acuator , 2 ,one on each side of the dash, correct part #?
    i think the actuators are only on digital climate controls, the ones with the turn knobs have a cable still i think, i could be wrong tho.
  6. #6 Re: Blend door acuator , 2 ,one on each side of the dash, correct part #?
    Apr 2009
    Fort Worth TX
    The one's with the knobs are digital as well, just different form factor than the sliders.
  1. Blend Door Actuator Replacement
    By Abrasive in forum How To Write-Ups/Tech Tips
    Last Post: 08-02-2017, 04:59 AM
  2. Blend door
    By BADAZGTP in forum General Tech Discussion
    Last Post: 06-27-2016, 02:25 AM
  3. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
  4. Blend Door
    By 98GTPON22s in forum General Tech Discussion
    Last Post: 03-07-2012, 09:50 PM
