Thread: 97 regal pcm problem
Results 1 to 13 of 13
  1. #1 97 regal pcm problem
    Dec 2011
    Cortland
    For starters I have a 97 buick regal gs with i believe to be a PCM problem. I swapped a junkyard PCM in it with the correct OSID or whatever its called, but none of my gauges work when the car is started. I've tried two different 97 regal bins, both of which have worked for me in the past. I can write files to the computer fine but it almost seems as though I have the wrong PCM. I'm kind of lost on what to do. Any ideas? Heres a picture if it helps.
    Not sure which link will work on this forum so i will post a couple and one is bound to work.
    http://i1165.photobucket.com/albums/...410_191427.jpg
    <a href="http://s1165.photobucket.com/albums/q592/rankdropper84/?action=view&amp;current=IMG_20120410_191427.jpg" target="_blank"><img src="http://i1165.photobucket.com/albums/q592/rankdropper84/IMG_20120410_191427.jpg" border="0" alt="Photobucket"></a>
  2. #2 Re: 97 regal pcm problem
    What's the issue dude? looks like your temp gauge is working backwards and you can't see the LED displays. The display issue is about 20 minutes to fix wtih resistors and if the cluster is nto functioning properly..it's likely a bad cluster, not a pcm.
  3. #3 Re: 97 regal pcm problem
    I picked up a Regal where the temp gauge was backwards, all the lights were on, mileage was like yours...and the oil light flashed. Swapped the cluster out with another and it was magical.
  4. #4 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    WOW if that is really the problem then I am an idiot. I took it for a drive down the road and it wouldn't shift out of first, but now that i am thinking about it it might just be the TPS sensor. Going to go check that then I will report back.
  5. #5 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    Wait one more thing I should have stated. When trying to start the car, it will start itself once the key is in the ON position. Thats what led me to believe it was the PCM because I put a Grand Prix file on this regal before and that is exactly what it would do.
  6. #6 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    Also in that picture the car is running. Only thing that works is the speedo. The gas gauge and RPM even worked before I wrote a different bin file to it.
  7. #7 Re: 97 regal pcm problem
    Did you read the codes?
    here's the cluster resistor fix
    http://www.grandprixforums.net/how-f...dic-42095.html
  8. #8 Re: 97 regal pcm problem
    RPM shouldnt be dependent on the pcm..
    Fuel might be.
  9. #9 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    What would RPM be dependent on then? The crank sensor?
  10. #10 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    Just checked the codes, Nothing popped up other than an EGR code which is because I don't have it plugged in.
  11. #11 Re: 97 regal pcm problem
    What year bin files have you flashed to the pcm? different osid's may assign the pinouts differently and cause all kinds of issues.
  12. #12 Re: 97 regal pcm problem
    Dec 2011
    Cortland
    I used the bin file off of dhp for the 97 regal which I've used numerous times and I tried the 97 regal bin file that dark horizon provided from his sticky on clubgp. I've tried writing to it using the pcm file vain and manually typing the vain. Both with no success
  13. #13 Re: 97 regal pcm problem
    Have you pulled the cluster to see if the connector is loose?
  1. My Regal and GTP
    By Ridin ON Chrome in forum Members Rides
    Last Post: 07-20-2013, 12:46 AM
  2. my 97 regal gs
    By jim97regalgs in forum Members Rides
    Last Post: 07-29-2011, 02:21 PM
  3. regal gs and gtp
    By BoostJunki3 in forum Track Sessions and Kills
    Last Post: 09-17-2009, 09:10 PM
  4. Hello! No Regal Yet
    By theedgeofsanity in forum Buick Regal
    Last Post: 09-26-2008, 11:37 PM
  5. Regal from PA
    By RLewis15 in forum Introductions/Noob Questions
    Last Post: 01-21-2008, 11:44 PM
