Thread: Trans pan gasket
Results 1 to 6 of 6
  1. #1 Trans pan gasket
    May 2008
    I got a replacement filter from Autozone that comes with a new gasket. The gasket is just smooth rubber though. Should that be okay, or should I go ahead and get the Felpro gasket that has the ridges on it? My old one is leaking, so I have to replace it no matter what.
    Thanks,
    Steve
    Stock gasket or a new one from a dealer is all id use.
    The trans filter package should tell you yo reuse the factory gasket if it is the ridged/ metal bolt hole style.
  3. #3 Re: Trans pan gasket
    Take a good look at your current gasket. Make sure it's bad and not just loose/dirt in the seal etc.
    I wouldn't use that rubber pos unless I had no other choice.
  4. #4 Re: Trans pan gasket
    Napa sells rubber coated metal gaskets.
    But like they said above, re-use the stock gasket.
  5. #5 Re: Trans pan gasket
    May 2008
    One of the beads on the gasket looked overly mashed down, so I went ahead and got the Felpro replacement which is identical in appearance. Very glad I used that instead of the terrible POS floppy rubber gasket that came with the filter.
  6. #6 Re: Trans pan gasket
    It's funny.. I do a lot of these for people and have a bunch of stock gaskets on the wall from disassembling other transmissions etc. If they don't have a metal inlaid gasket when they arrive..they have one when the leave. I almost refuse to use the supplied gasket in the kits. Although it would work.
  1. intake manifold gasket or head gasket
    By Eric Whitter in forum 3.1L V6 (LHO/LG8)
    Last Post: 05-17-2012, 01:55 AM
  2. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  3. 1997 2nd design 4T60E Trans pan gasket
    By Pauley in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-01-2011, 07:06 AM
  4. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
