To change this over there are two ways to do it.
1. Change the connector at the trans and add 5 wires from the connector to pcm. Then program pcm for the different trans.
2. Change the harness and pcm, and program pcm for the motor/trans.
yeah got pcm flashed today motor started right up. what i was wondering if i could gut the 98 dash harness for the trans controls and add them to my 97 harness that way still be able to keep my abs and my body plug would be the same. also need to wire in for the diffrent evap system. p1665 po452 our only codes im getting and fuel gage isnt working right shows on empty when plugged in and goes to full when unplugged.....thanks for your reply this been not so much fun and not much info on it either.
