Thread: '04 GP GT2 Car won't start!! NEED HELP!!!
Results 21 to 40 of 50
  1. #21 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    4. you have a clogged fuel filter, change the filter first, if no fuel still, prepare to drop the tank.
    4 out of 3 people have trouble with fractions
  2. #22 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    SE Level Member 02SuperSport's Avatar
    Mar 2012
    Orlando
    Not an expert, but I would think if you hear the pump come on, but it's not pumping, the module is not the problem. I'd replace the whole pump.
    Brian
    '04 GT2
  3. #23 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    no need to drop the tank in grand prix, fuel pump access panel in the trunk.
    and yes you can just change the pump, and reuse the rest of the pump housing.
  4. #24 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Shellman Bluff, GA
    Only took them six years to add the access panel?
  5. #25 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Isn't the 04+ returnless system filter in the tank?
  6. #26 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    well tomorrow I'm going to mexico (live about 15 mins away) and get it there for about 45 bucks I already called and the cool thing is that I don't have to drop the tank like on my Grand Am. In the process I'm also changing the fuel filter...
    '04 | GP | GT2 | 162K
    Not an Expert | Just for the love of working on cars
  7. #27 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Shellman Bluff, GA
    Don't know Bill, I haven't played with any 04's.
  8. #28 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Quote Originally Posted by lrscgod View Post
    What? The 97-03's have the access panel and that was a 7 year run.
  9. #29 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    does anybody has some pics or a website that show how to take out the fuel lines.
    I have the disconnect tools but don't seem to fit and I don't want to break the actual housing lines from the fuel pump.
    any ideas??? suggestions??
  10. #30 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    looks like squeeze and pull it off, if this is the kind you have.
  11. #31 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    well I changed the fuel pump last week and it turns on but I have to crank it like 2 or 3 times before it actually turns on...
    any ideas on what's causing the issue??
  12. #32 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    was that right after you put the battery back on, if so its normal.
  13. #33 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    well, it's been about 3 days already and it still does it..
  14. #34 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    read wrong, not sure, maybe the throttle body's real dirty.
    after you pull the battery, every time i un hook my car it takes a few turns of the engine before it starts, but it goes away after a few starts.
  15. #35 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    any recommendations on what cleaner to use or any cleaner will do?
  16. #36 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    GTP Level Member Rico's Avatar
    Apr 2009
    Fort Worth TX
    I read the entire thread and nowhere do you say you've replaced the fuel filter or checked fuel pressure.
    It's a CUMMINS Dodge not a Dodge Cummins
  17. #37 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    I already changed the fuel filter, haven't checked the fuel pressure cause I don't have the gauges.
    What is the right pressure?
  18. #38 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Apr 2009
    Fort Worth TX
    Around 45 to 55 psi
  19. #39 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Mar 2012
    Edinburg, TX
    so if it's low how do I get it there..
  20. #40 Re: '04 GP GT2 Car won't start!! NEED HELP!!!
    Apr 2009
    Fort Worth TX
    On the 04 I believe the regulator is in the tank. You've replaced the pump already, right?
  1. No start/help please????
    By 97gmgtp in forum General Tech Discussion
    Last Post: 12-04-2010, 11:11 PM
  2. No start need help
    By Seanstud in forum General Tech Discussion
    Last Post: 11-28-2010, 10:07 PM
  3. Hot start help
    By makenzie71 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2010, 09:59 PM
  4. Where should I start?
    By Basher in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-05-2009, 09:44 PM
  5. no start
    By betsgtp in forum General Tech Discussion
    Last Post: 06-05-2009, 12:19 AM
