Thread: does anyone know what there IAT is?
Results 1 to 7 of 7
  1. #1 does anyone know what there IAT is?
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    i just put an open cone filter on the end of my TB and i was wondering if anyone knew what the IAT was just kinda a ball park im worride about the air being too hot also what is a dangerous IAT
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: does anyone know what there IAT is?
    300+?????
    The air does not get heated up until it enters the blower and or UIM.
    So you are fine.
  3. #3 Re: does anyone know what there IAT is?
    Oct 2011
    Michigan
    really i just put on an open cone and im kinda paranoid, its just on the end of the TB and it gets pretty hot in there i dont wanna cause dentination (spelled it wrong i know)
    Pcm will correct for higher iat's.
  5. #5 Re: does anyone know what there IAT is?
    Oct 2011
    Michigan
    so what you all saying is that i really have nothing to worry about with a open cone on the end of the TB on a bone stock 99 GTP?
  6. #6 Re: does anyone know what there IAT is?
    Apr 2009
    Fort Worth TX
    Quote Originally Posted by asite57 View Post
    Detonation
    There ya go
  7. #7 Re: does anyone know what there IAT is?
    You'll be fine. It might throw your maf sensor off a little but on a stock gtp you should be ok. My iat's are maybe 5* warmer than the outside temp.
iat
