Thread: mystery gas smell
Results 1 to 14 of 14
  1. #1 mystery gas smell
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    ive got this gas smell and im stumped on where its coming from, i can smeel it when i turn the car off after driving it home and open my door. its not comeming from the engine bay (i thought it was bad injector rings) it seems to be coming from the rear. part of my fuel line broke and someone put a rubber hose there with hose clamps that was leaking at one point but i tightened it done now its dry. im thinking its coming from the sending unit im gonna pop the door off in the truck and see what it looks like in there is there a seal that could have broke or something?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: mystery gas smell
    Apr 2009
    Fort Worth TX
    Those sender o-ring seals leak all the time and installing a new one is a biaaatch.
  3. #3 Re: mystery gas smell
    Oct 2011
    Michigan
    whats the harm in just letting it leak? i now the fumes can ignite but is there ever really a spark on top of my gas tank?
  4. #4 Re: mystery gas smell
    Apr 2009
    Fort Worth TX
    "Do ya feel lucky, punk?" Are you willing to take the chance over a $3.00 seal?
    Let me give it to you straight. Your gas tank is leaking fumes; it's an inveritable bomb. Find the leak and fix it.
  5. #5 Re: mystery gas smell
    Yoga city
    Yup listen up alot of gp's go up in flames, you wanna become a statistic?
  6. #6 Re: mystery gas smell
    I'd just fumble around the car with a lighter to find said leak.
  7. #7 Re: mystery gas smell
    Apr 2009
    Fort Worth TX
    HaHaHa. Seriously, this is no laughing matter.
  8. #8 Re: mystery gas smell
    Agreed...gas leaks should be found, fixed and made safe.
    I don't seem to share Chuck's knowledge of the tank rings leaking often, but I do know how to install them with ease. If it's that...let's get you a write up and show you how to do it the easy aka Boost way. And yes..I have one here that needs a pump/ring.
  9. #9 Re: mystery gas smell
    Oct 2011
    Michigan
    Well the pump was replaced 7 months ago before I bought the car, it was done by a hack shop though if I pop off that cover how can I tell if the rings bad? Is it obvious?
  10. #10 Re: mystery gas smell
    I'd sniff. If you smell gas and you smell it or see it on top of the tank..then hit that seal.
  11. #11 Re: mystery gas smell
    Apr 2009
    Fort Worth TX
    Have at it Bill.
    I'm on pins and needles. LOL
  12. #12 Re: mystery gas smell
    Wont be til at least monday...I do have one to install though. Or I could just pull up old pics from a previous installeroooooni.
  13. #13 Re: mystery gas smell
    Apr 2009
    Fort Worth TX
    I want video, faacker!
  14. #14 Re: mystery gas smell
    Oct 2011
    Michigan
    Thatd be sweet if I could see pics bill! Definitely will do it
  1. mystery plug
    By 98regal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-27-2012, 05:50 AM
  2. mystery sound??
    By spider4 in forum General Tech Discussion
    Last Post: 11-18-2011, 06:02 PM
  3. Oil line mystery
    By 62duoglide in forum General Tech Discussion
    Last Post: 04-12-2011, 05:14 PM
  4. Mystery Vac line!!
    By Pittman06 in forum General Tech Discussion
    Last Post: 12-22-2009, 08:18 PM
  5. Mystery problem with S/C
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-23-2009, 01:08 AM
