Thread: Difference between 04/05 and 06-09 engines
Results 1 to 9 of 9
  1. #1 Difference between 04/05 and 06-09 engines
    They seem to have different timing cover sets. Newer being metal and older being paper and the same as series 2.
    Did the timing cover not change until 2006?
    I also noticed in 06+ there are no pan gaskets listed. They appear to use rtv instead.
    Any harm in using the paper gasket with the newer engines?
  2. #2 Re: Difference between 04/05 and 06-09 engines
  3. #3
    Gasket is half the cost.
    Mostly why im interested.
  4. #4 Re: Difference between 04/05 and 06-09 engines
    No difference in the gasket. On teh oil pan, GM went from a rubber inlaid gasket in the 00 Bonneville L36 with aluminum pan to an engine bonding/sealant gasket in the 04 GP aluminum pans.
  5. #5 Re: Difference between 04/05 and 06-09 engines
    2000 Bonne pan for comparison
    GP pan
  6. #6 Re: Difference between 04/05 and 06-09 engines
    i used a metal gasket on my car when i did it, honestly.
  7. #7 Re: Difference between 04/05 and 06-09 engines
    It's funny..I've used both. Sometimes the fel pro kit has metal...other times paper.
    I ask because 06+ are less expensive than any other s2+ n/a engine from this particular wrecker.
    Older timing gasket it is. No need for the conversion set.
  9. #9 Re: Difference between 04/05 and 06-09 engines
    May just be where the evap or other crap was located and how it works in the Hollander exchange that people aren't looking for that motor.
  1. School me on Engines
    By DoubleBlown in forum Engine
    Last Post: 02-06-2012, 07:43 AM
  2. What vin 1 engines.....
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 08:03 PM
  3. For the ones with top swapped engines.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2010, 01:18 AM
  4. Jasper Engines....anyone know anything about them?
    By Zef_66 in forum Off Topic Discussion
    Last Post: 08-13-2008, 04:23 PM
  5. Some bling for these engines...
    By GR8racingfool in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-20-2008, 10:13 PM
