Thread: Gas Mileage decreasing
Results 1 to 17 of 17
  1. #1 Gas Mileage decreasing
    SE Level Member CRASHMAN55's Avatar
    May 2011
    OSHAWA,ON
    Hey people. I am a little baffled. I was getting some good gas mileage 6 months ago. But since then its been decreasing. i have new plugs, wires, filter, PCV valve, and air filter. I did a throttle body clean and cleaned the sensors and ranSEA foam in the brake booster vacuum line and put some in the tank as well..
    Car idles fine (900 rpm)and runs fine. There is a slight bit of hesitation when i stomp on it during acceleration. 2000 GP GT 145000km.
    I am getting an o2 sensor (AC delco) soon. Hopefully this will work. Any other suggestions?
  2. #2 Re: Gas Mileage decreasing
    Wouldnt hurt to clean the maf sensor with maf cleaner.
    Which plugs did you put in it?
  3. #3 Re: Gas Mileage decreasing
    Is it throwing any codes?
  4. #4 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    No codes. But I cleared some codes a while back,( low coolant ) as the heater bypass connector went, so I replaced it.
  5. #5 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    Platinum NGK, and I used alcohol to clean the sensors.
  6. #6 Re: Gas Mileage decreasing
    Our cars don't like platinum plugs. I'm not sure about the alcohol to clean the sensors that may have messed up your maf.
  7. #7 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    I get 400km (250miles) city. per tank
  8. #8 Re: Gas Mileage decreasing
    Quote Originally Posted by CRASHMAN55 View Post
    250 miles per tank is not that bad.
    I seem to avg 16-19 MPG's and I only drive city.
  9. #9 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    I used to get alot more. And i am super light on the pedal.
  10. #10 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    Would a unfinished drive cycle after removing neg. bat cable do anything?
  11. #11 Re: Gas Mileage decreasing
    Platinum plugs get destroyed by the waste spark system.
    Switch back to some AC delco Iridiums and most of you mpg loss should retrun.
  12. #12 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    Well, my mileage has been down for a while. I just did all of this last week.
  13. #13 Re: Gas Mileage decreasing
    well depending on what plugs were in before, it could have something to do with it.
    Buy I would for sure put some iridiums back in, to rule that out. They are the best plugs for a stock motor.
  14. #14 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    And when i pulled the other plugs out, i did notice 2 back ones were wet with gas. Fuel injector leak? The others looked great.
  15. #15 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    Well maybe i will try the iridiums. cant hurt.
  16. #16 Re: Gas Mileage decreasing
    Apr 2012
    Sinsinnati,OH
    I've been having the exact same problem with my 2003 GP GTP..... I just replace my platinum plugs (which I put in a few years ago) with auto lite iridium....also replaced the wires.
    I will post back any MPG improvement.
  17. #17 Re: Gas Mileage decreasing
    May 2011
    OSHAWA,ON
    I hope it works for you Ron
  1. Mileage
    By JakeH0605 in forum General Grand Prix Discussion
    Last Post: 01-01-2012, 10:55 PM
  2. Gas Mileage
    By Remnant King in forum General Tech Discussion
    Last Post: 04-19-2011, 04:51 PM
  3. BAD gas mileage
    By tc300 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2011, 01:51 PM
  4. low gas mileage?
    By coreygnar in forum General Tech Discussion
    Last Post: 06-07-2010, 09:44 PM
  5. What can I do to get better gas mileage?
    By isucyclones3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 11:58 PM
