I have a 1998 gtp and I did a ic set up with ported sc well the battery went dead in the winter so I pulled the cluster out to change the bulbs to leds, well when I was puting other gauges in I pulled one wire out the went to the harness to the pcm, well long story short the cluster and hud won't work I bought a new cluster hooked it up in my other car and it work put it in my gtp and non, and when the battery was dead I pulled one of the harnesses out and hooked the wire back up. So Idk if that would have anything to do with it but I need HELP plz
