Thread: correct axle
Results 1 to 7 of 7
  1. #1 correct axle
    SE Level Member fhaines's Avatar
    Apr 2012
    Lebanon, Ohio
    I bought a new passenger side axle but it doesn't have a cup like the original, is this possible with an aftermarket axle?
    2000 Grand Prix GT Metallic Green 4 Door
  2. #2 Re: correct axle
    The two ends of the passenger axle... One is splined the other has splines and threads.
  3. #3 Re: correct axle
    Apr 2012
    Lebanon, Ohio
    Ok so this is normal? And it doesn't have an ABS ring on it. This normal as well?
    Thanks,
    Fhaines
  4. #4 Re: correct axle
    abs is all in the hub assembly.
  5. #5 Re: correct axle
    Correct, and I'm thinking you are a Ford guy talking about the ring on the axle.
    Our speed sensors are within the wheel hub. Which makes them cost triple what they should.
  6. #6 Re: correct axle
    Apr 2012
    Lebanon, Ohio
  7. #7 Re: correct axle
    Apr 2009
    Fort Worth TX
    Yep, that's the passenger side. It has external splines that slide into the differential. This where the differene is between a L67 and L36 axle.
    Driver's side has internal splines that slide over the output shaft.
    What do you mean by "cup"? If the one you removed had a "cup" then, well, IDK! The internal spline on the driver's side axle kind of looks like a cup.
  1. Correct tie rod nut?
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2011, 10:12 PM
  2. Correct PS Fluid?
    By FriboRage in forum General Tech Discussion
    Last Post: 05-25-2010, 09:18 PM
  3. cant seem to run the 'correct' afr
    By fst in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 11:24 AM
  4. Is this how to correct?
    By Brammer in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-19-2009, 01:52 PM
  5. Am I correct?
    By Bogers99GTP in forum Off Topic Discussion
    Last Post: 09-08-2008, 08:25 PM
