Thread: Can I take my o2 sensor out to see if my cat is clogged?
Results 1 to 10 of 10
  1. #1 Can I take my o2 sensor out to see if my cat is clogged?
    Dec 2010
    DMV
    Can I remove the sensor and see if that makes a difference before I replace the cat?
  2. #2 Re: Can I take my o2 sensor out to see if my cat is clogged?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    My initial thought would be no. However, perhaps unbolting the downpipe that leads to the cat would help you troubleshoot. Hopefully one of the gurus will chime in.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: Can I take my o2 sensor out to see if my cat is clogged?
    Yeah you can pull out your upstream o2 and drive around and see if it gets better and if it does then your cat is probably clogged. What symptoms are you having?
    Dec 2010
    DMV
    Bogging under slow acceleration especially at around 50 mph. It's showing a service light for a p420 code as well. Just thought I would rule everything out before I buy the cat
  5. #5 Re: Can I take my o2 sensor out to see if my cat is clogged?
    Knoxville, TN
    Won't unplugging the upstream O2 sensor cause the car to run like crap either way, just due to how the computer uses the data?
  6. #6 Re: Can I take my o2 sensor out to see if my cat is clogged?
    For as short of a period you are going to have it taken out (as in removed from the exhaust), it wont matter.
  7. #7 Re: Can I take my o2 sensor out to see if my cat is clogged?
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    Here's an idea from the "I live in Florida so I don't care if it poisons the environment" handbook: Remove the Cat and U-Bend either way.
    The evil LG8 still refuses to die.
  8. #8 Re: Can I take my o2 sensor out to see if my cat is clogged?
    Yes you can. Don't drive it hard though, because it won't know what the fueling is and therefore you don't want to beat on it.
  9. #9 Re: Can I take my o2 sensor out to see if my cat is clogged?
    Feb 2009
    flintnasty MI
    Tell that to uh, all my cars!
    Running with no o2 will have zero ill effects, so knock yourself out and dont be afraid to rag on it.
    Ohio
    Whenever I had my front o2 out it ran like ****. Going easy on it was alright but if I jumped on it, it said hell no
  1. do i have a clogged injector or a bad coolant temp sensor
    By athalflife3 in forum General Tech Discussion
    Last Post: 07-09-2013, 02:14 AM
  2. clogged cat
    By jrocthakidd in forum General Tech Discussion
    Last Post: 10-07-2011, 08:06 AM
  3. Possible clogged cat
    By black plague815 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-15-2011, 11:02 AM
  4. Cat clogged
    By wingman65 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-31-2011, 07:26 AM
  5. Clogged cat, bad o2?
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2009, 01:38 PM
