Thread: General price range for headers installation?
Results 1 to 7 of 7
  1. #1 General price range for headers installation?
    Dec 2010
    DMV
    Getting headers soon and leaning towards the good ole "home driveway install" but was wondering what would a shop typically charge to install? I called one and they said 475. cheese and rice (Jesus Christ lol) is it that much labor involved? Also I need my cat changed and the same shop that did my mufflers for 225 wants to charge me 375 for a cat install. Really? Wtf is wrong with mechanics? I mean isnt a cat Install a simple cut and weld?!
    Are all mechanics crooks!?!?
  2. #2 Re: General price range for headers installation?
    its all labor time, and figure 5-6 hours to do it.
    I did mine in a pull barn with a few extra hands in about 7 hours.
    Dec 2010
    DMV
    Shop it is. dammit.
    Bunnell, FL
    Did mine with a member here in 13 hours. But I have a 97 so the big problem was the trans dip and the trans cooling lines
    Android Fire
    I'm a Sex Offender
  5. #5 Re: General price range for headers installation?
    Shop it is. dammit.
    Why?
    Do it yourself and get the cat welded in after you are done.
    And find a place that will do it for cheap. If you bought a highflow cat, most can just clamp in with the rest of the exhaust.
  6. #6 Re: General price range for headers installation?
    I charge guys about $350 to do it. I follow the instructions I've posted as "the easy way" and it takes about 6-7 hours to do a good job. On the cat, buy a 3" cat and clamp it in like the rest of the exhaust.
    If you put on Speed Daddy's and get FrozenBoost clamps, get an extra one or two of the 3" and you can easily clamp a cat in place, instead of the straight pipe they send. I've done it tons of times.
    If you look at those instructions, you'll see I never mention the dipstick tube. That only comes into play on W body or TOG headers. Otherwise they all fit fine with the stock tube on a W body car.
    Tools you'd need.
    Jack
    Jackstands
    2x4 or 4x4 about 18 inches to 3 feet long
    13mm socket
    10mm socket
    15mm socket
    18mm socket
    Ratchet
    Hammer
    Sharpie marker
    Onlly places that fight are the firewall where the O2 sensor would hit. So you move it with your hammer. The rear manifold to DP bolts, but they dont' matter, because you could wiggle them out the bottom with the subframe down a little. The catback flange bolts. Those are easy to cut and replace though.
    Dec 2010
    DMV
    I'm going to continue to shop around for better prices to get the cat welded in or try the clamp in cat and I'll try my best to attempt the headers install. Thanks guys
  1. Trip to the range
    By IR II IP IDEATH in forum Off Topic Discussion
    Last Post: 02-27-2011, 05:10 PM
  2. mid range struggle
    By venge24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 03:43 PM
  3. WTF? Why do strut mounts have such a wide price range?
    By FuglyGTP in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2010, 10:40 AM
  4. range rover
    By Davisgtp in forum Off Topic Discussion
    Last Post: 03-15-2010, 07:34 PM
  5. Bad MAP??? What should the range be?
    By l67fiero in forum PCM Tuning
    Last Post: 08-14-2009, 01:54 PM
