Thread: Water pump replacement
Results 1 to 5 of 5
  1. #1 Water pump replacement
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    It looks like my water pump is weeping through the weep hole, so it's replacement time. I looked through the how-to forum to see if there was a thread on this, but didn't see any. I'm guessing it's pretty straight forward, but if anyone has a link to a write-up, or tips/tricks, that would be great.
    What all has to come off to do this? Belt, alternator, alternator bracket, coolant reservoir... what else? Should I use a gasket to seal the new one up or use RTV? Is it easiest to go in from the top or through the wheel well?
    Thanks!
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  2. #2 Re: Water pump replacement
    yeah its a easy job.
    1 st tip, break the 4 bolts on the wp pulley lose before you take the belt off. tighten the same way, last thing you'll do.
    if your s/c'ed, you need a t 55 to remove the belt idler, its blocking a bolt, and i took the power steering pump off it was blocking a bolt as well but others have said they got it out with out removing it, so play it by ear.
    after you get the pump off, clean up the gasket surfaces, and use just a gasket, no rtv. the 4 long bolts clean them up and put thread sealant on the threads, these bolts go into the water jackets of the block. when you remove them coolant will leak from the threaded holes.
    pump off note the lower idler pulley is off. ( by the crank) and the p/s pump is off as well.
    and back on.
    i painted my new pump, it was sitting for days before i put it on, so i figured why not.
  3. #3 Re: Water pump replacement
    oh and i unbolted my fuse box and moved to the side for more room to work.
  4. #4 Re: Water pump replacement
    Nov 2010
    West Fargo, ND
    Thanks for the info!
    Last edited by Ophidia; 03-29-2012 at 07:46 PM. Reason: Reread response and realized I didn't actually read it the first time.
  5. #5 Re: Water pump replacement
    Nov 2010
    West Fargo, ND
    It was indeed an easy job. I did have to move the power steering pump out of the way to get to one of the water pump bolts. It's nice to have a car that doesn't smell like antifreeze anymore.
  1. water pump
    By fatty13 in forum General Tech Discussion
    Last Post: 03-15-2011, 09:40 PM
  2. Water Pump???
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-12-2011, 11:26 PM
  3. Water Pump replacement
    By Reddcurrlz in forum General Tech Discussion
    Last Post: 02-25-2011, 04:07 PM
  4. Radiator and Water Pump replacement 95 Prix SE Coupe
    By Soultempter in forum 3.1L V6 (LHO/LG8)
    Last Post: 08-20-2009, 12:08 AM
  5. Water pump ?
    By GTP4 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-10-2008, 01:21 PM
