Thread: Crank-camshaft wiring harness
Results 1 to 4 of 4
  1. #1 Crank-camshaft wiring harness
    SE Level Member A70Runner's Avatar
    Dec 2011
    NC
    I replaced my crank sensor on my 00gt. Now I get a code for the cam sensor. I noticed the harness is cut. I guess I messed it up. My question is...can you remove the wiring harness to fix/replace it without pulling the dampener? Does anyone sell this harness in case I can't repair it?
  2. #2 Re: Crank-camshaft wiring harness
    Saratoga NY
    Without pulling the dampener yes, the harness runs to the icm. You can find the harness in the for sale section or you can place a wanted add. Good luck.
    98-XP e85 SSAC HPT AGX Bullets Every BRM piece home built trans
    99-HPT ssic headers ported blower
    94z28 with a cam that chops so hard it hurts def peopels ears.
  3. #3 Re: Crank-camshaft wiring harness
    spice and solder with some shrink wrap, should all be good, if you have a clear shot at the broken wire.
  4. #4 Re: Crank-camshaft wiring harness
    Junkyard or someone likely has it hanging around. Heck..I'm sure I have one.
    You can get the connector off w/o pulling the dampener, it's a little more work though.
  1. 04 wiring harness
    By Explicit_Spade in forum Audio, Security & Visual Electronics
    Last Post: 08-30-2011, 04:38 PM
  2. Do I need a wiring harness?
    By cyclones in forum Audio, Security & Visual Electronics
    Last Post: 03-30-2011, 07:46 AM
  3. Need some help, wiring harness meltdown! have some harness swap questions for a guru
    By pureroundcircle in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 09:23 PM
  4. Wiring harness
    By Dedlydragoness in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-15-2009, 04:51 PM
