Thread: HID relay harness question
Results 1 to 12 of 12
  1. #1 HID relay harness question
    Jul 2011
    westvirginia
    Bought 35w bi xenon kit from zzp, works good but drivers side sometimes will not turn on, it's like the ballast is not getting enough voltage, the relay I got from zzp has a 10a fuse, would upping the amperage maybe solve this problem? Should I try a 20a?
  2. #2 Re: HID relay harness question
    Waukesha, WI
    dont up amperage
    the wires might not be able to handle the extra power,
    i had the same problem, got pulled over for having a headlight out.
    went to a ddm kit and never looked back
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  3. #3 Re: HID relay harness question
    Jul 2011
    westvirginia
    Zzp 100 dollar kit lasted not even 2 months. Wtf is that. I'm thinking it's a faulty ballast or some bs. So I was gonna order 2 55w from eBay
  4. #4 Re: HID relay harness question
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    Go to ddm or vvme, I have 35w bixenon from vvme. Work perfectly. Don't go with 55w IMO
  5. #5 Re: HID relay harness question
    putting a bigger fuse in it does not increase the amperage. the fuse is there to protect against high amperage, not limit it.
  6. #6 Re: HID relay harness question
    The Boss Iceman6669's Avatar
    Jun 2011
    Interesting..... I am thinking of getting the same kit from ZZP.... Did you happen to have the HD Harness???
    2011 F-150 Yote powered
  7. #7 Re: HID relay harness question
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Have you tried to contact ZZP about this problem??
    For all your 3800 needs:
    Bunnell, FL
    I know I had a problem with the zzp harness and both bulbs
    Simply pit they hid kits they sell aren't worth it in the end especially with customer service.
    Now don't get me wrong I'm not a zzp hater
    Android Fire
    I'm a Sex Offender
  9. #9 Re: HID relay harness question
    Jun 2011
    Quote Originally Posted by z3r0 View Post
    Android Fire
    I think I will still get the one from ZZP cause I live here in Grand Rapids, so any customer support should be pretty straight forward.
  10. #10 Re: HID relay harness question
    Jul 2011
    westvirginia
    I have not even bothered contacting zzp, from what I hear on this website you're better off not even attempting to contact zzp lol
  11. #11 Re: HID relay harness question
    Jun 2011
    Quote Originally Posted by mattstansbury View Post
    0_o..... It NEVER hurts to at least try.....
  12. #12 Re: HID relay harness question
    May 2011
    wisconsin
    Go to ddm... I have lows highs and fogs 5k 35w from them and have had zero problems so far. Its been about five months since I installed them. I also have relay harnesses install on all of them.
  1. 2007 GP HID Harness and DRL Relay Chatter Question
    By Nylox in forum Visual/Body Modifications
    Last Post: 01-21-2012, 10:10 AM
  2. which relay harness?
    By cody116 in forum Visual/Body Modifications
    Last Post: 08-10-2011, 04:29 PM
  3. HID Flickering with relay harness ?
    By jmalm321 in forum Visual/Body Modifications
    Last Post: 12-02-2010, 12:56 PM
  4. relay harness questions
    By Slueth66 in forum Audio, Security & Visual Electronics
    Last Post: 02-27-2009, 04:14 PM
