Thread: Wheel bearing install goof.........
Results 1 to 4 of 4
  1. #1 Wheel bearing install goof.........
    SE Level Member Freimuth's Avatar
    Nov 2009
    Clinton, Ohio
    So I did the driver side no issues..
    Was finishing up on the pass side and the abs wire was pinched and I cut the wires.. DOH!!!!!
    So does anyone know if i splice the wires back together if it will work or am I totally up a creek and have to buy another hub??
    Thoughts?
    Thanks.
    New to me ---- 1999 Grand Prix GTP 216K miles and counting
    SOLD----1997 Grand Prix SE 3.8 -- 1K miles from the 200k club.
  2. #2 Re: Wheel bearing install goof.........
    solder it together and it should be fine.
  3. #3 Re: Wheel bearing install goof.........
    Nov 2009
    Clinton, Ohio
    Both wires are the same color stripes. Do you think it matter which I solder to which?
  4. #4 Re: Wheel bearing install goof.........
    Kansas
    Solder and try. If it throws a code, cut and swap and repeat.
  1. Wheel bearing or other?
    By Pointman in forum Brakes/Suspension/Chassis
    Last Post: 08-22-2011, 11:36 AM
  2. wheel bearing hub
    By learnAsUGo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2011, 09:43 AM
  3. ABS wheel bearing/hub on non ABS car?
    By Captain Bravo in forum Brakes/Suspension/Chassis
    Last Post: 01-01-2011, 03:15 PM
  4. Possible bad wheel bearing?
    By Cail in forum General Tech Discussion
    Last Post: 09-01-2010, 12:32 PM
