Thread: 2008 Grand Prix Door Lock Issue
Results 1 to 6 of 6
  1. #1 2008 Grand Prix Door Lock Issue
    Mar 2012
    Richlands, NC
    Both of the front door locks in my GP are not working properly. The back ones work just fine, but with the front ones it's hit or miss. Once in a while they will work, other times they will try to work, most times they do not work at all. I'm thinking it's most likely a short somewhere in the wiring, but do not know for sure. Has anyone experienced similar issues and if so how did you fix it?
  2. #2 Re: 2008 Grand Prix Door Lock Issue
    GT Level Member GMCustomerService's Avatar
    Michigan
    2008GrandPrix,
    An issue with the door lock actuator is another possibility. I encourage you to have it inspected by a certified technician. They will be able to offer a more accurate diagnosis, and repair options, after a physical inspection.
    Louis
    GM Customer Service
  3. #3 Re: 2008 Grand Prix Door Lock Issue
    Mar 2012
    Richlands, NC
    Is that true even if it's both of the doors and not just one?
  4. #4 Re: 2008 Grand Prix Door Lock Issue
    Kansas
    Please be more specific. Are you trying to lock them from inside? Are you using the key fob? Give a little better description.
  5. #5 Re: 2008 Grand Prix Door Lock Issue
    GT Level Member SoergBot's Avatar
    Oct 2011
    Dayton
    Quote Originally Posted by 2008GrandPrix View Post
    Almost like they short out? Ik sometimes after I take the key out of the ignition and go to unlock the doors so i can grab something from the back, it doesn't work, so i will have to throw the key in quick, turn it a click to get the electricity flowing and then it usually works, dont know why it does this, happened 3-4 times since i bought the car
  6. #6 Re: 2008 Grand Prix Door Lock Issue
    GTP Level Member
    Nov 2011
    Kansas
    Mine did it right after I replaced my door speakers. It is like the doors had to relearn how to operate properly. But mine was only with the door lock switch, never the key fob. It is all fine now.
  1. 2008 Grand Prix Door Lock Problem
    By SMac68 in forum General Tech Discussion
    Last Post: 11-21-2017, 10:59 PM
  2. cruise control issue 2008 grand prix gxp
    By akwaks in forum General Tech Discussion
    Last Post: 01-28-2012, 06:56 AM
  3. 2006 Grand Prix front left door lock
    By walder1 in forum General Tech Discussion
    Last Post: 12-07-2011, 09:59 PM
  4. 2008 Grand Prix no start issue
    By supernac in forum General Tech Discussion
    Last Post: 08-22-2010, 11:57 AM
