Thread: 4* of KR what do you think is causing it??
Results 1 to 9 of 9
  1. #1 4* of KR what do you think is causing it??
    SE Level Member JcGTP39's Avatar
    Jul 2011
    Grand Rapids Michigan
    Alright the other day I tested my car with my scanner and did a KR sensor scan, just to see if I still have any KR after I just put headers on and 3inch full exhaust.. So all my mods are listed in the bottom box and i check my fuel pressure at idle its at 50psi then at WOT its 62-64psi. Before the headers she had 7* of KR now shes down to 4* for fuel all I run is shell 93, but this weekend im going to try something and see if it helps out any im going to get down to 1/8 tank of fuel then get two gallons of 110 octane and see if helps the KR at all cause if it doesnt then it could be some false but I will find out. I just wanted to see if you guys had any other ideas on what is should do or test. So let me know thanks.
    97 GTP. ZZP CAI, ZZP Custom Dyno Tune, Drilled 180* Tstat, Voltege Booster, A104's, ZZP Wires, 3.4 Pulley, ZZP Stainless Headers with TOG down pipe, ZZP 3 inch Stainless Cat Back.
  2. #2 Re: 4* of KR what do you think is causing it??
    Ohio
    downpipe smacking sway bar?
  3. #3 Re: 4* of KR what do you think is causing it??
    When does it knock?
    All the way through the power band or just at the top of shift. Does it just spike to 4 and go away?
    I also say get a real tune now, that ZZP tuned pcm may not be cutting it.
    Also knowing AFR at WOT would help.
  4. #4 Re: 4* of KR what do you think is causing it??
    Jul 2011
    I dont really feel anything smacking, I know the cross over pipe does come in contact with the tranny dip stick and does create a little vibration.
  5. #5 Re: 4* of KR what do you think is causing it??
    Ohio
    that would do it. put it in 2nd and do a full pull.
  6. #6 Re: 4* of KR what do you think is causing it??
    Jul 2011
    When we did the test it spiked at 4 once it hit 3500-4000 RPM and stayed between 3 and 4 didnt go to zero. Im going to do another scan tmrw and ill get you the AFR at WOT as well. But yeah i was thinking about maybe getting it dyno tuned and see if thats would get rid of it all.
  7. #7 Re: 4* of KR what do you think is causing it??
    Out West
    It's real KR.
    You need valvetrain mods and a real tune
    Whine with your Cheese?
  8. #8 Re: 4* of KR what do you think is causing it??
    You have a wideband o2?
    Otherwise a scanner, like say a Tech 2 or somethnng wont know what it is really, it'll just tell you what the computer might be commanding.
  9. #9 Re: 4* of KR what do you think is causing it??
    Jul 2011
    Yeah I have a snap on Modis scanner that will pretty much tell me anything. Yeah I kinda figured it might be real KR but you never know
  1. HID lights causing static!
    By hockeybawler in forum Visual/Body Modifications
    Last Post: 02-08-2012, 11:35 PM
  2. What is causing this?
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-21-2011, 01:30 PM
  3. What's causing this?
    By BwolfGT in forum General Tech Discussion
    Last Post: 10-02-2009, 04:57 PM
  4. What is causing my MAF to go out?
    By MartinTD in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2009, 04:33 PM
  5. AC compressor is causing my RPM to surge?
    By JCGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-19-2008, 01:48 PM
