Thread: Synthetic Brake fluid
Results 1 to 10 of 10
  1. #1 Synthetic Brake fluid
    SE Level Member ryan12473's Avatar
    Dec 2010
    Iowa, Burlington
    I'm going to switch to synthetic brake fluid when I install F- body brakes. Which dot fluid do I use?
  2. #2 Re: Synthetic Brake fluid
    GTX Level Member f3racer's Avatar
    dongducheon, south korea
    make sure its 5.1 instead of dot 5. dot 5 is best for non abs set ups using parts that can withstand much higher heat ratings than a stock system. dot 5.1 is best for abs setups using stock parts. i used 5 on my race bike and ended up destroying the brakes because the fluid got so hot that it ate all the rubber seals and stock brake lines. 5.1 is glycol based and does not get nearly as hot.
    personally on a street car that doesnt see much if any roadcourse duty i would use dot 4.
    SSG US Army Military Police
    2006 Grand Prix GXP
    http://gmls4.com
  3. #3 Re: Synthetic Brake fluid
    Pennsylvania
    "ideally, silicone fluid [DOT 5] should be used only to fill non-ABS systems that have not been previously filled with glycol based fluid. Any system that has used glycol based fluid will contain moisture; glycol fluid disperses the moisture throughout the system and contains corrosion inhibitors. Silicone fluid does not allow moisture to enter the system, but does not disperse any that is already there, either." - wikipedia
  4. #4 Re: Synthetic Brake fluid
    2006 Grand Prix GXP
    http://gmls4.com
  5. #5 Re: Synthetic Brake fluid
    Feb 2009
    flintnasty MI
    dot 3 and nothing else please.
  6. #6 Re: Synthetic Brake fluid
    Pennsylvania
    I am under-educated on brakes. Why dot3? Also, don't f-bodies come with dot4?
  7. #7 Re: Synthetic Brake fluid
    Feb 2009
    flintnasty MI
    Fluidics
    All GM cars take Dot3.... some motorcycles use dot4.
    Ohio
    Vw's use dot 4
  9. #9 Re: Synthetic Brake fluid
    my brake fluid cap says DOT4.
    2006 Grand Prix GXP
    http://gmls4.com
  10. #10 Re: Synthetic Brake fluid
    Pennsylvania
    Fluidics
    But dot4 and 5.1 are able to be used as well. Why not use those?
  1. brake fluid
    By donalda in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-21-2011, 04:56 PM
  2. Low Brake Fluid??
    By jezzer in forum Brakes/Suspension/Chassis
    Last Post: 07-27-2011, 10:12 AM
  3. Synthetic Tranny Fluid
    By mikesarebetter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-30-2009, 09:01 PM
  4. brake fluid
    By grand2000prixgtp in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2009, 06:51 PM
  5. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
