Thread: Weird sunroof problem
Results 1 to 6 of 6
  1. #1 Weird sunroof problem
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    I searched a bit but i couldent find anything quite like this. My sunroof draws enough current to blow the fuse weather im using it or not. Im talking a constant 20+ amp draw. I put a 30 amp fuse in just long enough for it to very slowly close. The fuse was hot when i pulled it back out. Seams to work just fine (although slow due to the strange current draw). I havent had time to ohm check the supply side to ground yet but i will when i get home. What do you guys think? 2001 gt
  2. #2 Re: Weird sunroof problem
    Sep 2011
    Copperas Cove, TEXAS
    IMHO, bad ground or power supply wire being grounded. Hope you can find it. I hate all electrical except stereo install haha.
  3. #3 Re: Weird sunroof problem
    Apr 2011
    South Dakota
    I cant check until around 1 or 2 this afternoon but im guessing something is shorted in the switch. A bad ground wouldent cause the excessive draw even when the sunroof is sitting unused i dont think. Im going to ohm check power side to ground and ground to battery ground anyways.
  4. #4 Re: Weird sunroof problem
    Apr 2011
    South Dakota
    I just unhooked the motor and sunroof switch and there is still a draw. What else should I eliminate?
  5. #5 Re: Weird sunroof problem
    GT Level Member Peacher213's Avatar
    STL Metro Area
    You have a short somewhere. Id look at some wiring diagrams, and start searching.
    99 GTP coupe
    Stock, other than open cone filter.
  6. #6 Re: Weird sunroof problem
    Apr 2011
    South Dakota
    I wish i could find a proper diagram. Anyone ever post the full.schematics on here?
  1. sunroof problem
    By hodge9386 in forum General Tech Discussion
    Last Post: 11-17-2011, 07:33 PM
  2. Sunroof problem
    By 2005GrandPrix in forum Audio, Security & Visual Electronics
    Last Post: 11-12-2011, 09:38 AM
  3. sunroof problem
    By t3791518 in forum General Tech Discussion
    Last Post: 01-07-2011, 02:52 PM
  4. 95 GTP sunroof problem
    By 67GTO in forum General Tech Discussion
    Last Post: 07-25-2010, 09:33 PM
  5. Sunroof problem?
    By 99GPGT in forum General Tech Discussion
    Last Post: 04-25-2008, 10:40 PM
