i found a blown fuse under the hood. it was #24 15a its labled elek ign. its odd because its one of the first things i checked when the problem first happened.
Yeah I checked all of my fuses and didn't find anything that was obviously blown...really don't know whats wrong with mine
check ur ground circuit, it may be the icm itself as well. mine started out with a bad ignition coil and the icm was bad. i dont know when the fuse blew, it was good before i did any work to it
Check this site out, it really helped me;
Part 1 -GM Main Index of Articles.
Thanx man! Yeah I found that earlier and i am going to test everything...it is weird though because I have changed the icm and crank sensor...only other thing I can think of is either bad ground or broken wire somewhere...guess I better recheck the fuses also
