Thread: DP gasket keeps going out
Results 1 to 6 of 6
  1. #1 DP gasket keeps going out
    Jan 2009
    Tallahassee, FL
    I keep blowing DP gaskets, I never had this problem before the motor swap. Stock manifold to 3" DP. I just changed it on Tuesday so its making it a real pain to tune right now. It went out doing WOT runs. I got another one from OReilys that I'll put in tomorrow. Can you over torque or any special gasket that's better than the others?
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
    Pic of blown gasket?
    Gm > all.
    Or use rtv on both sides.
    Jan 2009
    Tallahassee, FL
    The gasket looks fine, the DP keeps coming loose so I'll throw some locktite on them tomorrow
    77 Morris Garage B
  4. #4 Re: DP gasket keeps going out
    RTV the pee out of it like Matt said.
    Then, loctite the bolts.
    And make them tight, and let it sit for an hour or so.
    Jan 2009
    Tallahassee, FL
    I'll skip the RYV, never had that work out for me lol. I'll locktite and tighten them when it hot so they'll stay nice and tight hopefully.
    77 Morris Garage B
    Jan 2009
    Tallahassee, FL
    Locktited the nuts today, they were already a little loose but not enough for it to start leaking. If it happens again I'll double nut it lol
    77 Morris Garage B
  1. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  2. Look what a bad UIM Gasket can do.....
    By aussie in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-20-2011, 03:36 PM
  3. Oil Pan Gasket
    By jacobmh27 in forum General Tech Discussion
    Last Post: 12-01-2011, 09:38 AM
  4. PCV Gasket
    By chuckross1957 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2011, 09:44 AM
  5. LIM Gasket, Head Gasket, or bad sensor?
    By GTFiske in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 08:40 PM
