Thread: Fuel pump brands
Results 1 to 10 of 10
  1. #1 Fuel pump brands
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    Rock Auto has a fuel pump, customer service said it was a drop in, for just under a hundred bucks. Its called an 'UtlraPower'. Looks like the W-Body Stores drop in model for almost $60 less. Anyone have any experience with this???
  2. #2 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    bump...anyone? Rock Auto....ULTRAPOWER Part # UP35420M $96.79.
    Carter also has 2 closeouts remaining for $155.00.
  3. #3 Re: Fuel pump brands
    No info on it.. but likely since W body store doesn't make anything..it may be the same pump merely marked up.
  4. #4 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    it looks the same...The only problem with it is the description is sparse...it say includes wiring and "LS". Does the GS and LS have the same pump?
  5. #5 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    RA guy said "I think it will fit".
  6. #6 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    looks the same to me best I can tell
  7. #7 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    I beleive that the GS and the LS had diff fuel pumps. i may just go with the one from the WBS because they have never given me an incorrect part.
  8. #8 Re: Fuel pump brands
    I beleive the pumps were different. LS was lower volume and ran constant.
  9. #9 Re: Fuel pump brands
    Minnesota
    If you have a 00' GS you will have a venturi pump. IIRC
    That pump you are looking at say: "LS" on it, which would lead me to believe it is a non-venturi pump. You could use it but I would stick to buying a venturi pump.
  10. #10 Re: Fuel pump brands
    Dec 2010
    Cincinnati, Ohio
    thanks will prob buy the drop in one from WBS
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Fuel Filter and Fuel Pump 04 Grand Prix!
    By bjornbjorn in forum General Tech Discussion
    Last Post: 04-12-2011, 12:26 PM
  3. Fuel pump or Fuel Pump Resistor
    By Dragan in forum General Tech Discussion
    Last Post: 01-28-2011, 08:01 AM
  4. Fuel pump / Fuel sender question !
    By 2001redfireGT in forum General Tech Discussion
    Last Post: 03-01-2010, 11:03 AM
