Thread: Need advice! head porting tips
Results 1 to 20 of 22
  1. #1 Need advice! head porting tips
    GTP Level Member OrangeL67's Avatar
    Nov 2009
    Michigan
    So I have my heads being ported out by Randy Hilbrand in Michigan. After talking to a lot of folks in various car clubs, it seems this man knows his stuff and is very talented. His style of porting a forced induction engine seems to be based on velocity. He has an impressive private machine shop, and dyno numbers from lots of cars showing 30-60 crank horse gains from his headwork alone.
    Right now he is doing his base p&p that he believes will net some pretty good horses. I'm also changing out the stock l67 valves for the larger l32 valves, and milling the guides to accept 600 lift.
    Anyways, he says the bulk of where power will be made is in the valve chamber area. (Between the exhaust & intake runners.) I originally wanted to port match the intake side, but he thinks it will not net much gains being that the engine is forced induction. He actually thinks I'd make more power with my cam by just smoothing the runners, slightly opening them up, and slightly manipulating the flow characteristics because "the air is going to get in and out without problems ".
    He says bowl work (polishing) looks pretty, but it wont be worth the labor. Any opinions? I ask because I can pay him to do these things, but I'd hate for it to be a waste of money. Thanks.
    VS cam build 13.01@107 316whp/ XP build #1 12.78@110 334whp/ XP build #2 12.56@113 347whp
    IS3 Cam build (Ready to put out some serious numbers)
  2. #2 Re: Need advice! head porting tips
  3. #3 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    Well that was easy lol.
    Why does every vendor match their heads and Polish the bowls? You'd think they would just do the basics and sell more heads cheaper.
    I guess I will just let the man do what he knows.
  4. #4 Re: Need advice! head porting tips
    exhaust is more important than intake for gains. the polished bowls are meh at best, i wouldnt even care to have that done.
  5. #5 Re: Need advice! head porting tips
    The trick on the intake side is to rough it up, because you want correct atomization of the air...not sure smooth, because then it just glides by. You do however want that on the exhaust side...smooth as glass is key as well as keeping the stock "D" shaped exhaust ports.
    In the heads yes, lim no.
  7. #7 Re: Need advice! head porting tips
    Sure.
    Didn't metion the LIM.
    Bowl in important.
    Its polishing the cc that isnt.
  9. #9 Re: Need advice! head porting tips
  10. #10 Re: Need advice! head porting tips
    .....oh, right. different words. i said it wrong.
    Isn't that the same as just being wrong? LOLOL
  11. #11 Re: Need advice! head porting tips
    i was talking about the combustion chamber as being the bowls. i use the wrong word.
  12. #12 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    Hell, now I'm confused lol. Is the bowl the important part, or the area where the valve stems run? He says it's the valve stem area where power is gained.
  13. #13 Re: Need advice! head porting tips
    the bowls are what the valve sits in. porting and polishing those youll see some good gains.
    polishing the combustion chambers is what you want to not car about.
  14. #14 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    Very well gentlemen. I appreciate the input. I just gave him a call to have the bowls blended and polished. I will have pics of the heads up in a week or so.
  15. #15 Re: Need advice! head porting tips
    Texas
    Sweet! Curious to see how much gains you get from the new heads.
    85 Corvette
    01 TA
    03 Z06
  16. #16 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    ^Me too lol.
    The heads are done. I'm picking them up Wednesday. I've got the runners done, intake runners opened up, but not matched. Exhaust. Side polished and opened, bowls swirl polished and blended. Competition valve job for slightly larger valves, and the valve chambers ported/ polished. This should amount to essentialy a stage 3~port job more less. Oh and for only $450. Maybe if I pick up some good power, you michiganders will have a reputable head porting source for on budget builds.
    I will post pics and dyno results after recent mods including Gen v, heads, and possibly 1.7 rr's. (Appointment is April 15)
  17. #17 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    I ended up going all out with them. These came out looking good IMO. We will see what type of power they produce
  18. #18 Re: Need advice! head porting tips
    How much did that cost and what all is done to them?
  19. #19 Re: Need advice! head porting tips
    Nov 2009
    Michigan
    L32 valve swap, viton valve seals, very nice 3 angle valve job, blended & polished bowls & combustion chambers, back cut valves, P&P intake runners, P&P exhaust runners, clearanced to accept 600 lift, rounded & polished short turn radius on intake and exhaust.
    We DID NOT quite match the intake runners, but he opened them up quite a bit. He said it wouldn't be wise to gasket match the intake side without opening up the full length of the intake runner ($200 more in labor) and even then, it would not yeild much power if any at all due to forced induction.
    Cannot say how much I paid bc to be honest, I got a great deal and I plan to make a profit off of these one day. How much?.. will depend on dyno results
  20. #20 Re: Need advice! head porting tips
    No cracks?
    Because that alone is impressive.
  1. HID\Projector Retrofit advice and tips
    By laferri2 in forum Visual/Body Modifications
    Last Post: 09-07-2011, 08:50 AM
  2. Rooted my droid X :) any tips or advice for a noob
    By vincegpking in forum Off Topic Discussion
    Last Post: 04-28-2011, 12:45 PM
  3. looking at 04 grand prix gt, advice/tips
    By staycool7989 in forum General Tech Discussion
    Last Post: 04-19-2011, 10:53 PM
  4. Need some advice for exhaust tips
    By 1998pontiacgtp in forum Visual/Body Modifications
    Last Post: 11-15-2010, 01:34 AM
  5. Head Porting?????
    By lambokit in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2009, 01:56 PM
