Thread: some one help please!
Results 1 to 16 of 16
  1. #1 some one help please!
    May 2008
    McHenry IL
    DRiving home from work today i noticed duh my instrument cluster lights are not on and my fogs are not on and the switch light isnt lit up! but my turn signals and stuff come on a light up??????? My dic lights up fine... someone please help me threw this problem?? Fuse im guessing but i checked some?? whats going on? this makes me sad also my dome light works when i open the door? Also when i oppen my door it dings loud and fast ???? "keys are not in ignition.
  2. #2 Re: some one help please!
    May 2008
    McHenry IL
    help me some1
  3. #3 Re: some one help please!
    gotta be a fuse or a short. hopefully a fuse..that might lead to a short..
  4. #4 Re: some one help please!
    May 2008
    McHenry IL
    do the guauge illuminations have its own fuse or tied in with fogs switch???? im lost and sad
  5. #5 Re: some one help please!
    SE Level Member crimpton's Avatar
    Aug 2008
    Portland, Oregon
    Dinging loud and fast means the car thinks the lights are on, or the key is in the ignition.
    I'm thinking light switch, or ignition switch.
  6. #6 Re: some one help please!
    Hoffman/Schaumburg, IL
    I would point to Light switch, does the Dimmer work?(on the radio or whatever does light up on the dash) Also, are your headlights working?
  7. #7 Re: some one help please!
    May 2008
    McHenry IL
    headlights are working no dimmer doesnt work i believe
  8. #8 Re: some one help please!
    If the dimmer doesn't work that the switch is very likely your problem
  9. #9 Re: some one help please!
    TDCRacing
    Guest
    its a fuse under the hood i will find out tomorrow exactly wich one it is and post the results back up.
  10. #10 Re: some one help please!
    May 2008
    McHenry IL
    tdc its 1 of the fuses in the engine bay panel?? if so ur a life saver!
  11. #11 Re: some one help please!
    ^^^ I doubt it, but for GTPjoe's Sake I hope I'm wrong and TDC is right
  12. #12 Re: some one help please!
    May 2008
    McHenry IL
    hay blue what are you saying could be the issue a switch? where is this switch and how much are they?
  13. #13 Re: some one help please!
    May 2008
    McHenry IL
    Well Guys I Solved The Problem =] Fuse #37 Under The Hood Blew =] It Was A 20 I Threw At 25 At Her Back To Normal =]
  14. #14 Re: some one help please!
    May 2008
    McHenry IL
    Thanks A Million Tdc For Sending Me In The Right Track =]
  15. #15 Re: some one help please!
    TDCRacing
    Guest
    It's fuse # 37 under the hood......lol.....No problem man.
    And everybody else that was thinking that it was the headlight switch that is exactly what i thought when it happened to my buddys car. But then we found out it was the one under the hood. Glad i could help.
  16. #16 Re: some one help please!
    May 2008
    McHenry IL
    no dude its 37 i think? well w.e it works now haha thanks again man i owe u haha
