Thread: HELP: tapping noise!
Results 1 to 3 of 3
  1. #1 HELP: tapping noise!
    So I swapped my AL103 side-gapped plugs with AL104s and gapped at 0.045 with no side-gap mod. Was out tuning and gotten on it on an open stretch then came to a coast and wanted to get off the freeway and pull a u-turn, once I slow down b4 exiting I heard a tapping noise. I puled over onto the shoulder of the exit ramp and popped the hood. I didn’t hear anything at that point so I blipped the throttle cable and sure enough the tapping noise I heard. It is in sync with the RPMs, meaning as the RPMs rises the tapping goes quicker. First thought was broken fl;explate but I called lysander and he said usually a broken flexplate u can hear at idle and not when u apply throttle. So I babied it to my brother-in-law a few miles down and checked around the engine bay. The tapping seemed to be coming from cyl #3 and #5.
    I pulled both plugs at 3 and 5 and they were fine. I called dubob and he suggested the possibility of a losoe rocker bolt. I opened the oil fill-neck and checked if the rocker bolts were re-useable or non-reusable, and from what I could glance at the rocker arm on the right of the opening, it seems to be a 3/8” bolt, meaning it’s the non-reusable. Now I haven’t popped the valve cover yet as its dark and I had to head home. Tomorrow after work im gonna pull the front valve cover and check if cyl #3 or #5 rocker bolts are loose. If that’s the case, what should I do as a next step? dubob was the one who did the cam swap for me, so I cant remember how to disassemble the rockers and rocker bolts
    i'll have to find the instructions i printed out about swapping and installing higher ratio rockers whe i was planning to get them installed on my own-but dubob did it for me too
  2. #2 Re: HELP: tapping noise!
    also could it be a bad lifter? again, it only starts to tap when i apply throttle. i understand theres a slight lifter tick when using aftermarket cams and stronger springs FWIW. the tap is very noticeable when gas is applied.
  3. #3 Re: HELP: tapping noise!
    Moore, Oklahoma
    Sure it ain't a rod bearing? A spun bearing will raise with RPMs too. Check your old, you may find something.
    How about a leaky header? Pacesetters ain't the best sealing out there, mayb check that too.
    Shawn W. Larsen
  1. Tapping noise at idle.
    By 04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-14-2008, 09:43 AM
  2. .... Noise again
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-24-2008, 04:15 AM
  3. What do you think this noise is?
    Last Post: 07-03-2008, 09:54 PM
  4. SC "tapping" noise... HELP!!
    By Cyko in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-16-2008, 05:30 PM
  5. growling noise
    By tjs84c10 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-13-2008, 02:06 AM
