Thread: Replaced EGR valve and gasket, SES still on
Results 1 to 20 of 22
  1. #1 Replaced EGR valve and gasket, SES still on
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Did i do something wrong? I got most of the old gasket off (It was basically disintegrated), took old egr off, put new one on. Start up car, light was still on. I didn't drive it around i literally turned the car on for like 2 minutes.
    The Boss Iceman6669's Avatar
    Jun 2011
    #1. some codes have to be cleared by a scanner.
    #2. Some codes will reset after so many miles of fault-free driving.
    2011 F-150 Yote powered
  3. #3 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    Approximately how long of fault-free driving? Drove all yesterday and a little this morning, code still on. How would i be able to tell if i did something wrong compared to me doing something right, but i just have to delete the code. I worry a lot lol
    Jun 2011
    I am not sure on the amount of miles needed.... But IIRC the egr code is one that will have to be cleared...
    Its not based on miles. The pcm needs time to run its tests.
  6. #6 Re: Replaced EGR valve and gasket, SES still on
    Cleaned most of the gasket off makes me think....leak.
    Yes..either it needs to be cleared or the pcm needs to run the test. If you looked up the code that you didn't provide to us in an FSM, then you'd understand how and when the code sets and clears.
  7. #7 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    Well i couldn't really take it off it was more of a "take a screwdriver and chip off the remains of the old gasket." Maybe that's my problem, don't know. I put a new gasket on then screwed everything nice and tight so i don't see how that could be a big leak, but you guys are the smart ones not me. I call my mechanic who always works on my car, he said i have to clear the code. My only fear is that i clear it, but then finding out something is still wrong. I don't have the actual code though
  8. #8 Re: Replaced EGR valve and gasket, SES still on
    It's all cool.
    I had a friend replace a waterpump. I explained that if only one thing was done right, it was cleaning the old gasket. She did that job a second time based on the gasket that was left behind. Not saying yours is an issue, it may be though.
    Not having the actual code, well...that makes it tough to determine how you should fix it.
    I hope the light disappears on it's own for you.
  9. #9 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    You know what, I'm almost positive i also have a code for a knock sensor because of all the rattle and noise my bad coupler is making. Thats probably why its still on.
    No idea whats causing my car to lag and not have full power at full throttle though.
  10. #10 Re: Replaced EGR valve and gasket, SES still on
    Jun 2011
    Quote Originally Posted by GTLGDP View Post
    I was not aware that the coupler rattleing will cause the Knock sensor to throw a code....
  11. #11 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    I think you just made me look really stupid, but thats what i was told lol
  12. #12 Re: Replaced EGR valve and gasket, SES still on
    I'm only aware of the knock sensors setting codes for bad voltage etc. Not for any knocking. They are there to pick up the knocking and retard timing based on how much they hear. FWIW I haven't come across one that thought coupler noise was engine knock.
  13. #13 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    I guess we'll find out once i change my coupler on thursday lol. I also went to Advanced Auto, they said they aren't aloud to clear codes. I even braught him out and showed him the replaced EGR valve, said he still couldnt -_-
  14. #14 Re: Replaced EGR valve and gasket, SES still on
    Jun 2011
    you can try reseting them yourself.... I have heard that by unhooking the battery and touching the battery cables together sometimes you can remove all the residual charge from the charging system... I have never tried it.. Just heard about it...
  15. #15 Re: Replaced EGR valve and gasket, SES still on
    Jun 2011
    BTW if you find a garage that is decent they might reset them for you for free.... Just had to go have mine scanned by a garage... My scanner doesnt do ABS codes....
  16. #16 Re: Replaced EGR valve and gasket, SES still on
    We won't find out.. take a look at the DTC code list and find a "engine knocking" type code. There's voltage and stuff like that. But your knock sensors are getting AC and then the pcm reads the feedback, which is why it's one wire per bank.
  17. #17 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    Here's the code. Should i just get a new sensor?
    OBD-II Trouble Code: P0327 Knock Sensor Circuit Low Input (Bank 1)
  18. #18 Re: Replaced EGR valve and gasket, SES still on
    Why wouldn't you follow the possible causes and test the things you can before shotgunning a sensor?
    Unless you really like getting a coolant bath that is.
  19. #19 Re: Replaced EGR valve and gasket, SES still on
    Oct 2011
    New Jersey
    I'm not good with technical car things so you're confusing me lol. I don't know what i could do?
  20. #20 Re: Replaced EGR valve and gasket, SES still on
    Well..the link you posted suggests this
    Possible Solutions
    • Verify the resistance of the knock sensor (compare it to factory specs)
    • Inspect for broken/frayed wires leading to the sensor
    • Check the wiring and connections leading to/from the knock sensor and PCM/ECM
    • Verify proper voltage is reaching the knock sensor (e.g. 5 volts)
    • Verify proper grounding of sensor and circuit
    • Replace the knock sensor
    • Replace the PCM/ECM
    I know you can look at wires, if you ask we can help you test resistance and voltage. Proper grounding... the sensor is in the engine block..lol.
  1. Valve cover gasket question
    By Compg4me in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2012, 01:00 PM
  2. rear valve cover gasket ?'s
    By twol8uluz in forum General Tech Discussion
    Last Post: 04-30-2011, 09:49 PM
  3. Valve cover gasket
    By Ricky21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-05-2011, 05:11 PM
  4. Valve cover gasket
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-14-2009, 10:25 PM
  5. valve cover gasket
    By BFish in forum 3.4L V6 (LQ1) DOHC
    Last Post: 12-12-2008, 03:51 PM
