Thread: roasted my old engine, need advise for my new engine.
Results 1 to 20 of 25
  1. #1 roasted my old engine, need advise for my new engine.
    GT Level Member SleeperGS's Avatar
    Dec 2010
    Cincinnati, Ohio
    engine decided to drop a valve and the engine tried to compress it. piston didnt like that, so.....BAM went the engine. Found a used one from a 2003 GTP with 70,001 miles. doing a tear down and its getting all new gaskets etc...im letting the rockers go and going CAM! What kind of gains should I expect with a VS cam? I already have 90 springs and dont want to do any head work. What are your thoughts. What is the biggest cam I can go without head work?
    thanks
    Ohio
    Do an s1x with 105s. Run a stock chain and you'll have alot of fun with it. But also, you can make dam good numbers with a vs for sure.
    The Boss Iceman6669's Avatar
    Jun 2011
    I would run the xp cam from zzp. A lot of people use it and have pretty good results with it.
    2011 F-150 Yote powered
  4. #4 Re: roasted my old engine, need advise for my new engine.
    Dec 2010
    Cincinnati, Ohio
    What is required for the XP cam? I already have 90# springs from the Yella Terra set up. Will these be strong enough? I also purchased a Cloyes timing chain (single) and Cloyes dampner. Will the retainers from the YT set up work?
    Quote Originally Posted by Iceman6669 View Post
    Vs makes similar power under the curve and is easier on the valvetrain.
    S1x its faster at the track thus the XP is a poor choice.
    Unless you're after sound. Then you should use a nic or gt2.
    Quote Originally Posted by SleeperGS View Post
    By cloyes, do you mean stock? If so yes, that'd be ideal. Just check tensioner in 30-40k.
    Lsx retainers are required for those valve springs.
  7. #7 Re: roasted my old engine, need advise for my new engine.
    Out West
    105 spgs
    Whine with your Cheese?
    Stock+Self Tuned. Going for low 14's everyday.
  8. #8 Re: roasted my old engine, need advise for my new engine.
    Dec 2010
    Cincinnati, Ohio
    So....., the cloyes is going to replace the stock chain and dampner. i have ordered these. Are the LSX retainers that you speak of the same as the retainers that I purchased for the YT rockers? And are the 90# springs good enough. Sounds like I need to go with the SX1. Where do you get the SX1?
  9. #9 Re: roasted my old engine, need advise for my new engine.
    Out West
    no. 105#
    id even go 130#
  10. #10 Re: roasted my old engine, need advise for my new engine.
    S1X and XP are relatively the same for power. S1X is Intense, XP is ZZP. The retainers you used should be the LSX/Modded retainers.
  11. #11 Re: roasted my old engine, need advise for my new engine.
    Dec 2010
    Cincinnati, Ohio
    and the retainers for the YT's are the same I guess....I thought so on the retainers, but wasnt sure on the springs.
  12. #12 Re: roasted my old engine, need advise for my new engine.
    Dec 2010
    Cincinnati, Ohio
    I need to go to 105's then and sell the 90# springs?
    Ohio
    My buddy runs comp 105s on his Bonne with the s1x and he's running very low 13s if that helps your decision
  14. #14 Re: roasted my old engine, need advise for my new engine.
    This buddy ran 105's on an S1X on his Bonne before going further and further. I loved the S1X, but the reality is...XP and S1X are nearly the same.
    Supposedly the s1x results in lower et's
  16. #16 Re: roasted my old engine, need advise for my new engine.
    Yet...most of us drive on the street. For the little bit that it might be faster and being a bigger fan of Intense than ZZP (based on customer service that I received) I should be the first to push in one direction. Yet..if a deal came up on an XP, I'd suggest he takes it.
    then run the vs. its cheaper and more dd friendly both to drive and on the timing set.
  18. #18 Re: roasted my old engine, need advise for my new engine.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    You'd be a fool to run aftermarket valve springs on a single chain and tensioner setup.....
    For all your 3800 needs:
  19. #19 Re: roasted my old engine, need advise for my new engine.
    Jason, you toss that out there... you feel that way about even something like the L76 springs? I was mentioning the CGP typically accepted info.
  20. #20 Re: roasted my old engine, need advise for my new engine.
    Orange County, NY
    Not necessarily Bill. I've seen what a higher rate spring does to a tensioner.........I'd just be wary about it. That's all.
  1. Engine Starts then dies after L36 Engine Swap! Help needed!
    By millertime2800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-18-2012, 10:50 PM
  2. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  3. Total engine rebuild, advise needed.
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-04-2011, 09:07 PM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
