Re: Need suggestions - Let's Mod My 04
speed daddy has relatively fast shipping
Well instead of a single build thread, we suggest you make a thread in the members rides section to keep all of the progress on your vehicle in one place.
Well here is a list that I can think of off the top of my head.. :th_winking:
- S1X Camshaft
- 105 Springs, Retainers, Locks
- Stock Timing Chain
- Timing Chain Dampner
- Gaskets (misc - engine is down to short block)
- LIM Gaskets
- Supercharger base gasket
- Cometic Head Gaskets
- Head Bolts??
- Rocker Arm Bolts??
- 3.4 Pulley
- Valve Covers ( either good used or whatever because mine are nasty and warped)
- Good Valve Cover Gaskets
- Supercharger tensioner pulley
- Idler pulley (has a crack and would like to replace it)
- Front Brake Pads
- Front Rotors
- Outer Tie Rod Ends
- Both Axle Shafts
- Radiator (I think I located one new locally)
- Trans Lines
- Power Steering Pump
- Water Pump
- 60lb injectors (would like to be able to run E85 and run 93)
- Fuel Pump (if needed)
- Engine Mounts (Not sure which would be best to go with here)
- Wide Range O2 gauge
This is just a start I guess.. All the trans stuff is coming from TEP
If anyone see's anything wrong with the list or thinks there is another way about doing things please feel free to chime in.
LapeerGTP
Ok, so while this thing is apart any other suggestions?
Yes, all the gaskets including the Oil Pan and main seals. You will thank yourself later.
The S1X cam is a great cam for stock heads. You will not be disappointed. In fact data was collected by various Grand Prix members and it was determined that the S1X had a better backhalf than the XP in the 1/4 mile.
Other than that you should have a fun car when everything is installed.
