Thread: Need some serious help no heat!
Results 1 to 9 of 9
shawnschuldt Need some serious help no... 02-25-2012, 07:25 AM
Explicit_Spade Re: Need some serious help no... 02-25-2012, 07:42 AM
dsmuts Re: Need some serious help no... 02-25-2012, 08:17 AM
shawnschuldt Re: Need some serious help no... 02-25-2012, 08:48 AM
dsmuts Re: Need some serious help no... 02-25-2012, 08:50 AM
shawnschuldt Re: Need some serious help no... 02-25-2012, 08:59 AM
chevyy1212 Re: Need some serious help no... 02-25-2012, 09:01 AM
shawnschuldt Re: Need some serious help no... 02-25-2012, 09:05 AM
chevyy1212 Re: Need some serious help no... 02-25-2012, 09:06 AM
  1. #1 Need some serious help no heat!
    GT Level Member shawnschuldt's Avatar
    Jun 2010
    Beloit, WI
    i have a 2000 gtp and i have the climate control,
    a couple days ago my blower motor just quit, if i changed the temp i could physically feel it change temperature so i know that part works, but the blower just quit, i havent had any time to pull anything apart but the weird part is that every now and then i can slam one of my doors and it will start working any idea? i really need some heat soon
    --00 Red GTP--
    CAR:E85--3.25"--SSAC Headers--ported gen 3--1.9 Rockers--AL 104's--65# Injectors--Zez wet kit 55 shot--9" AEM Cone--HP Tuned by me--No Cat--AEM
    13.07@108mph
  2. #2 Re: Need some serious help no heat!
    Omaha, NE
    Fuse or a ground possibly.
  3. #3 Re: Need some serious help no heat!
    Could be the bearing in the blower motor trying to lock up then when you slam a door it jars it just enough to make it run. If that is the case you could squirt some wd40 in the side and get a little more time out of it.
  4. #4 Re: Need some serious help no heat!
    Jun 2010
    Beloit, WI
    I'm not home so I want to cover my bases where would the ground be and the blower motor housing is where
    --00 Red GTP--
    13.07@108mph
  5. #5 Re: Need some serious help no heat!
    The blower motor is under the glove box.
  6. #6 Re: Need some serious help no heat!
    Jun 2010
    Beloit, WI
    How about the ground anyone know where to look fir the blower motors ground
    --00 Red GTP--
    13.07@108mph
  7. #7 Re: Need some serious help no heat!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    If you can get to a copy of the wiring setup check that out. I went an entire winter no heat blowing no defroster nothing in highschool. Id just give a chic a blanket when she said turn on the heat lol. Anyway there was a male to female plug under the hood. Come spring time had a new blower motor in hand..... I just followed the wiring diagram pushed in that plug a little.... POOF if worked man that sucked
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  8. #8 Re: Need some serious help no heat!
    Jun 2010
    Beloit, WI
    Ill have to check that out I had a subscription to alldatadiy but its expired now
    --00 Red GTP--
    13.07@108mph
  9. #9 Re: Need some serious help no heat!
    Oct 2008
    IL
    Library man. Thats where I got mine. Did I spell library wrong.. hmmmm
  1. No heat!
    By goldcrown61 in forum General Tech Discussion
    Last Post: 12-11-2011, 02:03 AM
  2. Help. I cant get very much heat.
    By squeaks130 in forum General Tech Discussion
    Last Post: 03-08-2010, 07:00 AM
  3. No heat in car
    By jibberlo in forum General Tech Discussion
    Last Post: 02-27-2010, 01:08 PM
  4. Heat and A/C??
    By lorenzojay in forum General Tech Discussion
    Last Post: 09-28-2009, 08:43 PM
  5. How much does heat......
    By GTP4 in forum PCM Tuning
    Last Post: 05-08-2009, 11:54 AM
