Thread: Torx socket question
Results 1 to 15 of 15
  1. #1 Torx socket question
    GTX Level Member blackflag's Avatar
    Virginia
    I've been looking all over the city for the torx e4 and e5 sockets and I cant find them anywhere. My next step is to just bite the bullet buy them online and just hope they get here soon. So my question is can i find an appropriate regular socket to use? Has anyone done this? Any suggestions?
  2. #2 Re: Torx socket question
    St. Louis
    Like this one from Autozone?
    Search: e4 | Driver Bit | AutoZone.com
    I would figure someone would have at least a 3 set or a 5 set you could buy to get the right one. You may be able to get away with using a 12 point socket, but not sure what size. Kinda looks like a 5/16 or similar.
  3. #3 Re: Torx socket question
    Virginia
    Yeah but they don't have it in stock here, I would have to order it. I need to fix this ASAP. Thanks for your help though
  4. #4 Re: Torx socket question
    GTP Level Member
    Oct 2011
    Raleigh, NC
    just curious, what are you fixing ?
    1997 Red GTP 182000 miles stock
  5. #5 Re: Torx socket question
    GTX Level Member bps02gtp's Avatar
    Nov 2010
    Illinois
    i am also curious because not to many things need the socket, just usually the bit.
  6. #6 Re: Torx socket question
    St. Louis
    The only thing that I can think of is either he's trying to remove the MAF, which requires a safety torx, trying to remove the TB, or trying to remove the 2 studs that the ICM/coils sit on top of, which if thats the case then I would just thread another nut onto the stud and tighten them against each other then stick a wrench on the nut closest to the head and remove as noraml using the outer nut to keep it tight. Or just vice grip the silly thing worst case, lol..
  7. #7 Re: Torx socket question
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Why ask if you can use a socket. If you have sockets in that size just try them, what can it hurt ?
  8. #8 Re: Torx socket question
    Virginia
    I'm changing out the ignition switch. It's my daily driver so I cant just have it apart for days if the socket doesn't work and I have to order actual torx sockets online.It's not a fast install from what I hear anyway so I just don't want to be stuck in the middle and have to put it back together
  9. #9 Re: Torx socket question
    GTP Level Member
    Oct 2011
    Raleigh, NC
    Is there a Harbor Freight near you ?
  10. #10 Re: Torx socket question
    Virginia
    There is! I can't believe I didn't think of it. I check
  11. #11 Re: Torx socket question
    St. Louis
    Either there or maybe a true value, or an ACE hardware. Lowe's, Home Depot...
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    The only place I could find one local was in a screwdriver set at my local sears. I tried harbor freight and everywhere else I could think of.
    Sent using my bionic thumbs from my sweet DROID Razr Maxx
    For all your 3800 needs:
  13. #13 Re: Torx socket question
    Virginia
    I've pretty much tried everywhere local and no one has it in stock, harbor freight was back ordered. I'm just going to try to do it without it today and I guess order it online if I feel like I'm going to strip it. Damn "safety bolts". If I had just ordered it online in the first place I might have it now.
  14. #14 Re: Torx socket question
    GTX Level Member noreasonwhyy's Avatar
    Michigan
    it was a ***** finding that e4(e5? whatever size it was) socket, harbor freights 6-packs or whatever were e5/e6 and larger. i think i found it at a classic auto parts store for like 3 bucks.
    97 GT - slow, rusty
    93 CTD - more slow, less rust
  15. #15 Re: Torx socket question
    Virginia
    I used a reg socket for the e5 worked like a charm, now for the e4 im sol. Im about to order it.
  1. LCA removal, What size torx?
    By Boosted02GTP in forum Brakes/Suspension/Chassis
    Last Post: 10-21-2010, 09:01 AM
  2. Re-wire 12vdc accessory socket
    By loneorca in forum General Tech Discussion
    Last Post: 10-05-2010, 12:03 PM
  3. Name this socket
    Last Post: 04-18-2010, 08:57 PM
  4. Tork Socket
    By 1997GtpRider in forum Introductions/Noob Questions
    Last Post: 02-23-2010, 04:11 PM
  5. Where to find torx studs
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-16-2008, 07:05 PM
