Thread: Another spring mod thread: IC mock up and shiny blower piktaaars
Results 21 to 31 of 31
Threaded View
  1. #1 Another spring mod thread: IC mock up and shiny blower piktaaars
    Minnesota
    So here goes again. Originally I just wanted a solid 3.4 setup as far as engine mods go. But I recently bit the bullet on a gen V set up. Gen V w/zzp mps hub,portem LIM, N*w/ adapter, LQ4 custom intake, and sensor pigtail adapters.
    Once my taxes get back il be picking up an inctercooler as well. Im leaning towards the phenolic core ones that are being sold on here. If anyone has any input on them, or an others it would be greatly appreciated! Im gonna peice everything together rather than buying a kit. Most likely will get the 3" thick fmhe from frozen boost.
    So I decided Im gonna take a stab at polishing the blower. I figure I have quite a bit of time before I start the actual swap so I can chip away at it until then. And even if I botch the sh!t out of it Ill just paint it. But so far I think its going pretty good. I would never attempt this without a die grinder tho haha
    Just foolin around with idea of how hard its gonna be
    Just sanded with 100,220,330 then 1000 for a few minutes each to see what it could look like in spot. I have since gone back over it and got rid of almost all the little scratches in the shiny part.
    I came accross this, and wasnt really sure what its for. Im sure some type of serial number or something? Anyone know?
    And as of 4am friday night this is where shes at so far
    Ill be doing a write up for it once im done. Im trying to take as many pics as possible through out each step. This is after just 100 grit sanding as much as I could get at with a die grinder sanding disks and a few other bits, and hand sandind to smooth out as much as I could with 100 grit. still alot of work to go, but its slowing getting there.
    Open cone, SSAC headers, cat delete, 8.5 MSD wires, 3.4 zzp mps, 180*, 104's, ported blower, DHP canned tune, 19" XXR 962s, DNA springs.
  1. Spring mod thread
    By Ricky21 in forum General Tech Discussion
    Last Post: 05-27-2011, 06:11 PM
  2. Spring rates
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 04-10-2011, 10:21 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. It's Spring in So. Cal.
    By surfinshell in forum West
    Last Post: 07-13-2009, 12:23 AM
  5. Spring Projects
    By drunknmunky in forum Visual/Body Modifications
    Last Post: 06-14-2009, 03:10 PM
