Thread: Knock retard on a NA
Results 1 to 20 of 20
  1. #1 Knock retard on a NA
    SE Level Member Ophidia's Avatar
    Nov 2010
    West Fargo, ND
    This is just curiosity (since I think it's normal). I recently got a bluetooth OBD2 connector and the torque app on my phone. Cruising on the highway, typically KR was 0, but periodically it would hop up to 2-3* (the highest I saw was 5.7*). This would be when going up a hill typically.
    I remember reading that NA engines will usually have KR, but I'm just not sure what's normal. The whole bluetooth adapter + Torque app is pretty cool :P
    2004 GT2 Leather, Sunroof, heated seats, other stuff, but only a little DIC. Also, Kawi Vulcan 2000 http://tinyurl.com/ophidia
  2. #2 Re: Knock retard on a NA
    I still don't think that torque reads the KR correctly, cuz I will just eb crusing along and randomly get 6* of KR.
  3. #3 Re: Knock retard on a NA
    Mine seems pretty accurate. I get about 2-3* at WOT in second.
  4. #4 Re: Knock retard on a NA
    Nov 2010
    West Fargo, ND
    I was thinking it looked accurate too, but I don't have anything to compare it to to be sure.
  5. #5 Re: Knock retard on a NA
    Apr 2011
    Tally, FL
    yeah but how much kr do you get at Wot mine instantly shoots up to 10-14 usualy around 3-5 at part throttle
  6. #6 Re: Knock retard on a NA
    Quote Originally Posted by slick2500 View Post
    Maybe it was accurate since you blew yer kar up?
    Quote Originally Posted by DoubleBlown View Post
    How are your motor mounts? Downpipe hitting sway bar? Could be false knock...might be real...my N/A GT had 8* on 87 octane...go put some 91+ octane in it. If it goes away then it is real...
  7. #7 Re: Knock retard on a NA
    i get 0* at part throttle the only time i ever get any is if i'm at wot and then it's not much really.
  8. #8 Re: Knock retard on a NA
    Nov 2011
    NY
    I just got the Bluetooth/OBD2 reader and used it the other day with the app (Torque) before I took things apart again to install my headers (yeah - Pacesetters!!!)...
    It seems to be accurate, got some KR going on at medium throttle (dropped pulley 3.5) without the headers and of course the Autolite XP Irridiums (I will be changing before starting her up again). So, when I fire the baby back up, with new copper plugs (605's), headers and Overkill's PCM, I'm hoping the KR will be gone or at least minimal... lol
    I hope that all sounds right?
    and oh, I've got 93 octane here so not too bad. Was looking around for 94 but hard to find.
    There is a place not far in CT that supposedly carries racing gas (100).
    Anyways, that Torque app is pretty good, used it on my two older vehicles (01' GP and 99' Ford Explorer) to read the codes they're throwing... I'd recommend it to anyone who wants to play, $20 direct from China and $5 for the app! Wonder if the developer could get it to do a case learn, then that would be off the charts!
    Regards!
  9. #9 Re: Knock retard on a NA
    Pennsylvania
    Yummy flash knock. Clean your MAF and Throttlebody and get back to us.
  10. #10 Re: Knock retard on a NA
    Donating User Odi's Avatar
    Chicago South Suburbs
    gt's knock stock. thats why you get rid of the ubend and if youre me, put 89 octane in there.
  11. #11 Re: Knock retard on a NA
    Pennsylvania
    He doesn't have a ubend.
  12. #12 Re: Knock retard on a NA
    If you want race gas w/o worrying about going to find it. Look up tolulene and get a calcuator to figure out the mix. You can typically find it at most paint stores.
  13. #13 Re: Knock retard on a NA
    Apr 2011
    Tally, FL
    not sure what you mean by that statement. installed ported lim, with new gaskets and hv3 insert. at Wot now i see high 7-8 kr then it goes down to 5-6, at part or half throttle its still at 3-5 and this is still all on 87. still havent done the lower mounts yet. how much kr does the u-bend account for?
  14. #14 Re: Knock retard on a NA
    93 will help your KR if it's not false KR. Fill it up twice with 93 and see if your KR gets better.
  15. #15 Re: Knock retard on a NA
    ^^That.
    I'm saying these things...
    1) You have Flow IN mods, where are the flow OUT ones?
    2) The octane comment was to say since you're running 87, go run a higher octane and if the KR levels go down then it probably isn't false since a higher burning fuel is killing the KR.
    3) Check the motor mount/trans mount...if they are toast and the engine is allowed to move enough, the downpipe could be making contact with the sway bar causing false knock. Easy way to get around this is flipping it upside down, getting solid rubber replacement mounts, flipping the upper dog bone mounts or getting polys...also...getting an aftermarket DP, or headers...would get rid of that knock most likely too.
  16. #16 Re: Knock retard on a NA
    GT Level Member thegipper's Avatar
    grafton, wi
    The most KR i've ever seen on my N/A is like 1* at WOT. I do have flow mods though and use 93 octane only.
    02 GT - HV3, 3800 Perf. Tuned, Plog, ER rockers, DP w/Magnaflow, CAI, 180* stat, Plugs/Wires, Poly Uppers, Driver mod.....
  17. #17 Re: Knock retard on a NA
    GTP Level Member 01gpgt01's Avatar
    Hagerstown,Md
    WHen I was n/a and stock I was seeing 7*. With a DP I was down to 2-3
    2001 GT. A few here and there mods http://www.streetfire.net/video/2001...ynp_208097.htm
    2009 Hummer H3 Solar flare premium
    GT Level Member tylerbinski's Avatar
    Canada
    Yeah .. on 87 octane I was seeing up to 5* of kr in my 2004gt. I was able to tune this out this weekend by adding a splash of fuel in the upper range of the maf table
    And its been a while but iirc 2-3* in my 1997 gt before the l67 rebuild /4t65e-hd + harness, pcm, dic swap.
    '04 BLK GP - .. Turbo :P
    GTP SIC - '02GTP | XP Cam | Intercooled Turbo Kit | Cutout....Fire mod 9/11
    GTPSIC '02 | Twin charge, XP cam et
  19. #19 Re: Knock retard on a NA
    I still saw KR with pacesetters and 94 octane.
  20. #20 Re: Knock retard on a NA
    Kansas
    I still see blips on KR on light throttle under load.
  1. Attack of the knock retard
    By shawnschuldt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2011, 06:51 PM
  2. Knock Retard when accelerating
    By xxmattfxx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-19-2011, 06:33 PM
  3. Knock Retard - Stock
    By rfmgtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2011, 02:05 AM
  4. Knock Retard
    By SJAndrew in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2010, 01:05 AM
  5. Knock retard question...
    By a98gtp4u in forum Introductions/Noob Questions
    Last Post: 09-08-2009, 05:10 PM
