Thread: Hud and abs light.
Results 1 to 3 of 3
  1. #1 Hud and abs light.
    palatine
    So, I have a 2000 gtp and the hud flickers on and off, and then yesterday I took a fast left turn and my abs light went on maybe wheel hub? i'm new to the car world so any advice would help thanks.
  2. #2 Re: Hud and abs light.
    SE Level Member Just Yourshadow's Avatar
    Fox River Grove, IL
    Hud flickering is most likely caused by cold solder joints on the photocell in the HUD unit. As for the ABS light wheel hubs would be my first guess.
    I start $hit like it's got3800
    02 Regal - Best E/T - Wouldn't you like to f#cking know
    76 Kawi KZ900
  3. #3 Re: Hud and abs light.
    You will need to use a scanner that can see ABS codes in order to read them. Then figure out which hub went bad.
  1. Replies: 5
    Last Post: 10-04-2012, 02:40 PM
  2. Replies: 1
    Last Post: 02-14-2012, 05:03 PM
  3. Service Vehicle light, ABS light and intermittent stalling
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2010, 10:33 AM
  4. Replies: 16
    Last Post: 01-23-2010, 09:43 AM
  5. ABS Light + Check Tire Press. Light Problems
    By element55 in forum Brakes/Suspension/Chassis
    Last Post: 01-30-2009, 02:34 PM
