Thread: Dyno Results
Page 15 of 15 FirstFirst ... 5131415
Results 281 to 295 of 295
  1. #281 Re: Dyno Results
    Leaving it along porting wise I'd agree as well, but for air atomization purposes, polishing would be a great benefit, inlet and outlet.
  2. #282 Re: Dyno Results
    LIM was ported and smoothed/polished up, wasn't it?
  3. #283 Re: Dyno Results
    Secret race mods.
    Just like the intake side of the heads, you want the LIM to be a little rough.
  4. #284 Re: Dyno Results
    Banned
    CT
    The LIM hasn't been polished or ported in any way.
  5. #285 Re: Dyno Results
    Thought that was the one you got off me.
  6. #286 Re: Dyno Results
    Banned
    CT
    It's the LIM that was In my original motor. I gave the other LIM to Ed to give back to you.
  7. #287 Re: Dyno Results
    Oh..odd, I thought I had given you the one with the temp sensor in it. Looked like the same position I had it in.
  8. #288 Re: Dyno Results
    Banned
    CT
    You tapped the hole for the temp sensor into my LIM when it was off the motor.
    Lim should be polished. Injectors aren't in the lim, but the head.
  10. #290 Re: Dyno Results
    Banned
    CT
    How much power is a polished inlet and LIM really worth?
    Too many factors.
  12. #292 Re: Dyno Results
    Banned
    CT
    With that being the only variable.
    Your blower might not respond to polishing. In theory it should help.
    But that's just theory.
  14. #294 Re: Dyno Results
    Mullet Member Wotgtp's Avatar
    Connecticut
    I would assume a ported LIM would make a big difference. I can't comprehend why gm would leave that much material in the runner to the gasket. The only thing I can think of is that they wanted to insure in the most underkill nature to have the air go into the heads with no interference from the edge of them. However it lookied like you could port the LIM a 1/4 of an inch all around the runners and still not worry about porting the heads to match.
    Keeping costs down.
    Cast pieces are less expensive than polished or cnc by far.
    There isn't that much room for opening up the lim.
  1. GTP Dyno Results!!!
    By OrangeL67 in forum Track Sessions and Kills
    Last Post: 10-17-2011, 11:25 PM
  2. ** Back from ZZP Trip - DYNO results **
    By Silver2kgtp in forum General Tech Discussion
    Last Post: 04-27-2011, 11:28 PM
  3. sexy results :)
    Last Post: 05-12-2010, 08:48 PM
  4. results on the 07 ss
    By joe deleon in forum Track Sessions and Kills
    Last Post: 05-10-2009, 01:06 PM
