Thread: Easy way to spot exhaust leaks?
Results 1 to 20 of 20
  1. #1 Easy way to spot exhaust leaks?
    GT Level Member GTLGDP's Avatar
    Oct 2011
    New Jersey
    Well my car is backfiring and lagging/studdering and its either cause by my bad o2 sensor, or i have an exhaust leak somewhere. When the cars running, it seems to me like i hear more sound near the front of the car than i do the back tail pipes. Its kinda hard for me to find exactly where it is, especially when my intake is sucking in air and make that loud as hell hissing sound. Is there any easy way to find the leak if there is one?
  2. #2 Re: Easy way to spot exhaust leaks?
    seafoam
  3. #3 Re: Easy way to spot exhaust leaks?
    or a cold morning at start up should show a leak, look under the car too resonators rust out to and tend to sound like a fart, like mine right now.
  4. #4 Re: Easy way to spot exhaust leaks?
    Oct 2011
    New Jersey
    Does seafoaming make a huge difference? My car has 115k miles and i'm positive the previous owners haven't done it.
  5. #5 Re: Easy way to spot exhaust leaks?
    It'll help and when you start it back up after doing it you'll be able to see where you exhaust is leaking from because smoke will be coming out of it.
  6. #6 Re: Easy way to spot exhaust leaks?
    GTX Level Member cerick08GP's Avatar
    Well, your problem could be any of a dozen different things. But I certainly wouldn’t believe an exhaust leak is causing your problem.
    But, you’re correct, it is time for you to replace that O2 sensor. On a related note if you do Seafoam the car, replace the O2 sensor AFTER doing it. And yes, Seafoam really does work. It does a great job for what is was intended to do. That said carbon build up may not be your issue.
    But it could be the MAF, a clogged cat, or who knows. Have you scanned for codes?
    Ten years of continuous driving excitement and counting!
    2008GP
    ||HV3 insert||PowerSlot rotors w/Hawks||LED interior||MSD 8.5mm
    2002GP||sold
  7. #7 Re: Easy way to spot exhaust leaks?
    Oct 2011
    New Jersey
    I scanned about a month ago and got P0137, the o2 sensor and thats it. I don't know if its changed since then. I'll have to get it rescanned. I'm also getting the o2 sensor changed tuesday so i doubt I'd seafoam before then. I also changed my oil last week..shouldn't you seafoam before you change oil? Should i just wait until i have to change oil again?
  8. #8 Re: Easy way to spot exhaust leaks?
    SE Level Member PALMCASTER GT1's Avatar
    PALMDALE CA
    I'm courious about seafoam , what does it do for any car ???
    04 GT1
  9. #9 Re: Easy way to spot exhaust leaks?
    seafoam helps clean out the inside of the motor the stuff is great i've used it on every vehicle i've owned.
  10. #10 Re: Easy way to spot exhaust leaks?
    no need to change the oil, if you dont put it in the crankcase, putting it down vac line just sends it into the cylinders and gets burned and causes the smoke.
  11. #11 Re: Easy way to spot exhaust leaks?
    Texas
    Over time an engine will get carbon build up which will hinder performance. This mainly occurs when the Owner drives the car at a slower pace and never really "gets on it."
    The seafoam will break up the carbon and clean the internals of the engine.
    It can be purchased at any parts store and added to the brake booster vacuum hose in small doses over several minutes. Some like myself opt to add the seafoam via LIM vacuum source.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: Easy way to spot exhaust leaks?
    Oct 2011
    New Jersey
    Is there a tutorial anywhere to do it on our cars? I've seen multiple ways, not knowing which way i should do it for my car.
  13. #13 Re: Easy way to spot exhaust leaks?
    I know there are videos on Utube of ppl doing it. As a few ppl have already said, just use the brake booster line to add it. Put like half in the gas tank, then pour the rest down the vacuum line while the car is idling. You really can’t go wrong, just be aware your car will likely smoke a lot. Seafoam-ing is independent of oil changes, but if your engine is really gummed up it is possible you could get a chunk on a spark plug or kill off the O2 sensor. The product it self doesn’t hurt anything, all the crap it kicks out of engine could though.
    2008GP
    2002GP||sold
  14. #14 Re: Easy way to spot exhaust leaks?
    On my gtp i just pull the brake booster vacuum line and pour it in the vacuum line with the car running. I use a whole bottle. Then i immediatly shut the car off for about 10 min then start it up and the smoke show starts.
    SE Level Member Compg4me's Avatar
    Dec 2011
    Grand rapids Mi
    I've heard that running seafoam thru the supercharger can eat the coating off the rotors. Any truth to this? Any other way to run sea foam that's not thru the brake booster?
    Dec 2011
    Grand rapids Mi
    Break booster vacuum line. I wasn't going to dump it in the break booster.
  17. #17 Re: Easy way to spot exhaust leaks?
    Texas
    Quote Originally Posted by Compg4me View Post
    I know it does from personal experience. I believe there is a writeup in the how to section.
    85 Corvette
    01 TA
    03 Z06
  18. #18 Re: Easy way to spot exhaust leaks?
    SE Level Member midrange's Avatar
    Belleville, Ontario
    To answer the OP original question, I believe seafaom was suggested because it causes alot of smoke, and it will help find the leak. Have a friend put his hand on the back of the tail pipe while you search for the leak after seafoam is used.. You'll find a leak in no time.
    Here, this will answer all questions about seafoam.. Also there is a how to vid . Sea Foam Sales Company
    2004 Grand Prix GT1
  19. #19 Re: Easy way to spot exhaust leaks?
    Pennsylvania
    Quote Originally Posted by midrange View Post
    What you could do is have someone take a big rag, not their bare hand, and plug up the outlet for the muffler to block the exhaust, that will build pressure in the exhaust system and you'll hear the ticking of the exhaust forcing it's way out of the leak. Just listen around for it. Dont just put your hand on the tail pipe, you'll burn the crap out of it, lol.
    As for the seafoam thing, yeah there will be smoke pouring out of whatever exhaust leak you have, so that's a good flag... when I did my seafoam I had 2 of my primaries on my powerlog just spewing smoke. I knew I had a leak but I thought it was the gasket I didnt replace... actually had the welds crack on the plog.
    Sport Edition Kv5 18x8
  20. #20 Re: Easy way to spot exhaust leaks?
    GT Level Member RegalGS98s's Avatar
    NJ
    Quote Originally Posted by txslow6 View Post
    Not only the possible supercharger rotor coating, but any carbon that's developed on the rotors taking up space. dsmuts said in another thread to run it through the vacuum T under the nose of the supercharger. But here is some links I found:
    http://www.grandprixforums.net/seafoam-2-52385.html
    Grand Prixs Of North America • View topic - Seafoam writeup
    This has been asked a few times lately so hate to say it, but might need another sticky or at least something in the writeup section. I didn't find anything there doing a search.
    SMGPFC #0330 - 3.25, Intercooled, Custom Tune, 1.84rr, LS6 Springs, roller timing chain, SLP Headers, Borla Exhaust, built Trans, B&M Trans Cooler, home cut poly uppers, gapless rings, N* TB, Ported heads.
    Soontocome: CAM?, Custom modified M112, home poured Poly Engine and Trans mounts
  1. Can you spot your car?
    By Slowpoke in forum General Grand Prix Discussion
    Last Post: 01-04-2012, 12:50 PM
  2. Can you spot your car?
    Last Post: 01-01-2012, 05:41 PM
  3. Can you spot the difference!?!?
    By Colossus in forum General Tech Discussion
    Last Post: 10-06-2011, 07:09 PM
  4. Valve Cover Gasket Leaks & Possible Intake Leaks
    By mechguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2011, 07:48 AM
  5. Can you spot my new appearance mod?
    By DuBob in forum Visual/Body Modifications
    Last Post: 04-10-2008, 09:04 AM
