Thread: 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
Results 1 to 4 of 4
  1. #1 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    SE Level Member shawnooohhh's Avatar
    Guyton, GA
    There's no way this is a tranny problem, It has to be electronics, because While driving, it will go from 1st, to second, then hesitate, shift hard into 3rd, and drastically shift into 4th.
    After first starting the car, it will do this and just cruise fine.
    The first stop sign i hit(bout a mile from my house), i accelerate, shifts fine 1st & 2nd, In 3rd it hesitates then shifts hard, And either doesnt shift into 4th, or it shifts into forth, i ride for 100ft. and it shifts all the way down to second. if i put it in neutral, let it slow down to 35mph, and put it back in drive, it gets both 3rd and 4th back.
    Someone told me that a maf sensor can cause a handful of sensors in Grand Prixs to believe they are shot, such as solenoids, and tcc. could the maf be the issue? I cleaned it. no change. replaced it with a maf from a junkyard, but it got worse when i did that, put the old one back in, back to the way i explained above.
    Also seems like it stays in 4th, or 3rd when slowing down to make a turn, it stalls when i go from a stop sometimes, and just putts along like a Manuel would if you let go of the clutch and started in 3rd
    P.S. Trans is rebuilt as of 30,000 miles ago.
    If you've dealt with this, some advise? please? lol
    "and when you do that GT's pulling up, yea!"
  2. #2 Re: 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    Dec 2011
    Grand Prairie, Tx
    Crankshaft Position Sensor?
  3. #3 Re: 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    Guyton, GA
    the code for ckps is being thrown, but i had someone make the maf sensor work, and all the codes went away. Im going to order a brand new one and see if that works, Should i reset anything after putting the new maf on?
  4. #4 Re: 98 GTP, Trans lossing 4th gear sometimes, shifts hard and slips into 3rd.
    Dec 2011
    Grand Prairie, Tx
    Just let it take its course, normally the system clears itself immediately after replacing or repairing the issue, if it doesn't drive it a couple days OR drive it about 10 miles at NO MORE than 58mph. This allows the system to check and make sure nothing is wrong.
    Also when doing that make sure you do not do any heavy acceleration, heavy braking, try to be as gentle as possible. We had to do this alot at my old job.
  1. 98 gtp, Lost 4th gear for a day, Shifts hard, Hesitates
    By shawnooohhh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-26-2011, 01:32 PM
  2. Shifts hard when hot.
    By JWillas92 in forum General Tech Discussion
    Last Post: 06-02-2011, 09:50 AM
  3. shifts hard and bogs in 2nd gear
    By nascartech in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-22-2010, 11:18 PM
  4. Hard shifts
    By grand prik in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-22-2009, 07:48 AM
  5. No 4th gear & slips/shacks at take off!
    By Stover in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2008, 12:13 PM
