Thread: Radiator Fan Problems
Results 1 to 3 of 3
  1. #1 Radiator Fan Problems
    Winnipeg
    My daughter has a 2002 Grand Prix - 3100. The radiator fan doesn't come on normally. The two fans normally would come on around 180 F (82 C). Now, they come on only at about 212 F (100 C). As such, the engine temp goes between 212 F (then fans kick in) and then drops to 180 F (after the fans stop again). Both fans will run when I turn the AC on & with with the interior blower fan on high. Also, both fans will run when I disconnect the ECT (Engine Coolant Temperature) Sensor.
    I read somewhere that this means the radiator fan relays and the Engine Coolant Temperature senor are fine (I'm not sure this is accurate). In the end, it seems to me the only causes could be a relay, the ECT sensor or the PCM. Hope it is not the PCM as I understand these are expensive. Any advice would be appreciated including possible fixes to bypass the PCM controls so the fans will run. It appears that we can drive the car - not sure it is good for the engine but seems to be OK as long as the temperature doesn't go higher. Thanks in advance!
  2. #2 Re: Radiator Fan Problems
    sounds normal to me.
    Stock fan settings are 214 and like 226.
    Coming on at 212 in traffic is normal.
    212 is not hot either.
    Your ClubGP Liason copgtp's Avatar
    Orange County, NY
    Sounds quite normal....I second that.
    Sent from my sweet DROID Razr Maxx
    For all your 3800 needs:
  1. Two Problems: Rusted Radiator and No AC
    By SlyBlackDragon in forum General Tech Discussion
    Last Post: 02-12-2012, 09:40 AM
  2. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
  3. Weird radiator problems...
    By CSteen85 in forum General Tech Discussion
    Last Post: 03-24-2010, 02:37 PM
  4. radiator
    By blown gt in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-14-2010, 09:17 PM
  5. radiator problems
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-01-2009, 05:21 PM
