Thread: gtp sluggishn
Results 1 to 20 of 40
JROCK1987 gtp sluggishn 02-23-2012, 02:19 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 02:24 AM
Fivefingerdeathpunch Re: gtp sluggishn 02-23-2012, 02:24 AM
NR92 Re: gtp sluggishn 02-23-2012, 02:43 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 02:39 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 02:42 AM
NR92 Re: gtp sluggishn 02-23-2012, 02:42 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 02:49 AM
NR92 Re: gtp sluggishn 02-23-2012, 02:58 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 02:46 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 02:50 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 02:49 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 02:51 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 02:58 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:05 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 03:07 AM
Pure2sin Re: gtp sluggishn 02-23-2012, 03:08 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:10 AM
Pure2sin Re: gtp sluggishn 02-23-2012, 03:15 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:09 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:25 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 03:25 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:28 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 03:35 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:40 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 03:43 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 03:49 AM
JROCK1987 Re: gtp sluggishn 02-23-2012, 03:51 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 04:02 AM
NR92 Re: gtp sluggishn 02-23-2012, 01:35 PM
chevyy1212 Re: gtp sluggishn 02-23-2012, 05:34 AM
Explicit_Spade Re: gtp sluggishn 02-23-2012, 05:54 AM
chevyy1212 Re: gtp sluggishn 02-23-2012, 06:28 PM
Compg4me My 2004 gtp also has tan... 02-23-2012, 02:34 PM
TLSheff Re: gtp sluggishn 02-23-2012, 03:17 PM
NegativeOne13 Re: gtp sluggishn 02-23-2012, 03:19 PM
dsmuts Re: gtp sluggishn 02-23-2012, 05:21 PM
matt5112 Re: gtp sluggishn 02-23-2012, 06:25 PM
Pure2sin Re: gtp sluggishn 02-23-2012, 06:09 PM
jrock Re: gtp sluggishn 02-23-2012, 11:20 PM
  1. #1 gtp sluggishn
    TENNESSEE
    hey guys need help with a few questions. my setup on my 04 gtp is cai 3.4 pulley zzp pcm, 160d stat, al 103's, 2.5 cat back. my aeroforce is reading 7.0 on knock and pw bank is 24.6 at wot which is rich as fu** so i purchased pacesetter headers and downpipe,also the fs intercooler from zzp.is this settup ok or would i need to change something
  2. #2 Re: gtp sluggishn
    Omaha, NE
    Did you read the "safely modding your 3800" thread?
    First things wrong, 04+ should not run 160* Tstat (that's even on the product page on ZZP) and 103's are going to be a stage colder than your want for just a 3.4 pulley and a pcm.
    Second thing that's wrong, You're on a 3.4 with just a zzp PCM. ZZP PCMs are known for running lean which creates knock. Where are the supporting mods for the 3.4 pulley?
    Get a wideband! It will help dial in your fuel trims when you get a tuner.
  3. #3 Re: gtp sluggishn
    First off.
    ZZP pcms suck.
    That 3.4 is WAYYYYYY to small of a pulley on a GEN V superhcharger.
    160º is way too cold, bump up to a 180 or back to stock.
    AL 103's are WAY too cold, try some 104's or even 605's.
    If you go to headers with a Intercooler, then MAYBE you can run that 3.4 without KR, maybe............
    Get a tuner or somebody with a tuner to do a custom tune or that thing is gunn blow up.
    I'm suprised its not dead yet with 7* kr and a ZZP tune on a 3.4 gen v.
  4. #4 Re: gtp sluggishn
    GT Level Member NR92's Avatar
    Atkins, Ia
    snap a picture of your supercharger and we should be able to tell you what you have
    2004 GTP Comp G -- Sold
    2006 GTO Magnuson supercharged
    2007 Ram 2500 QCSB 4x4 5.9 Cummins, Efi live, Exhaust, Intake N'stuff
  5. #5 Re: gtp sluggishn
    TENNESSEE
    i believe its a gen 3and thanks for the advice dont need to blow another one up. yes i said another one
  6. #6 Re: gtp sluggishn
    Omaha, NE
    You belive your 04 GTP supercharger is a Gen V? What year is the motor from that is currnetly in your car?
  7. #7 Re: gtp sluggishn
    Atkins, Ia
    you better listen to these guys, i have a 04 comp g that im putting a motor in because i blew the f*ck out of a piston and i had the supporting mods to back them up, I have to agree with fivefingerdeathpunch, 3.4 inch is too small of a pulley for a gen 5, I have a guy that will be adjusting my tune/scaning for kr before i even pull it out of the garage again, im gonna try and get the 3.4 to work because that's what i got but im telling ya get that pulley off there or get ready to buy a new motor.
  8. #8 Re: gtp sluggishn
    Omaha, NE
    Quote Originally Posted by NR92 View Post
    KR is something that happens under load, it's not something you can accurately scan for in the garage.
    It's really not that hard guys... This is straight from ZZperformance.com in the listing for their MPS
    04-05 GTP or Comp G & 06 GT supercharged
    3.8 pulley totally stock car
    3.6 pulley Colder Tstat & spark plugs, downpipe, Cold air intake (still could have KR)
    3.4 pulley all of the above plus a VS cam, or SS intercooler
    3.3 pulley 3.4 mods and a XP cam
    3.2 pulley 3.4 mods and a fullsize intercooler or an SS ic and a VS cam.
    Anything smaller than a 3.0 pulley will require a camshaft, headers, intercooler & injectors.
    *Cars with open cone intakes should run one size larger pulley.
    **All recommendations assume 92 octane or higher
  9. #9 Re: gtp sluggishn
    Atkins, Ia
    lol i know that i meant i wasn't going to drive it until he can make sure im not going to blow this motor up due to a bad tune or alot of kr!
  10. #10 Re: gtp sluggishn
    TENNESSEE
    its a 2005 engine with my 2004 supercharger and lower intake
  11. #11 Re: gtp sluggishn
    Omaha, NE
    Quote Originally Posted by JROCK1987 View Post
    That's a Gen V supercharger. Series 3 motor.
    If it's a natually aspirated block, that could be a small part of your problem as well.
  12. #12 Re: gtp sluggishn
    TENNESSEE
    it says gen 3 on the cover
  13. #13 Re: gtp sluggishn
    Omaha, NE
    SERIES 3, Not Gen 3.
    Series = Motor series
    Gen= Supercharger Generation
  14. #14 Re: gtp sluggishn
    TENNESSEE
    ok my bad, its just that the 05 intake hole was smaller than the much larger 04. thats why i just assumed i had the gen 3. and asfor being na it didnt have that intake
  15. #15 Re: gtp sluggishn
    Omaha, NE
    What intake hole are you referring to?
  16. #16 Re: gtp sluggishn
    TENNESSEE
    the actual blower hole
  17. #17 Re: gtp sluggishn
    Minnesota
    I don't know if I agree with the fact that in order to run a 3.4 on a Gen V you need a cam. lol
  18. #18 Re: gtp sluggishn
    Omaha, NE
    Quote Originally Posted by Pure2sin View Post
    For a Gen V, I do. For reference, It would be the same as a 3.2 on a Gen 3.
    I see 9-10lb of boost on my 3.4 with a cam.
  19. #19 Re: gtp sluggishn
    Minnesota
    I think a 3.4 on a low compression motor on a Gen V without a cam or IC is possible (depending on tune). High compression no.
  20. #20 Re: gtp sluggishn
    Omaha, NE
    04+ Use the Eaton M90 Gen V blower on a Series III (L32) Supercharged engine
    97-03 Use the smaller, less effieicent Eaton M90 Gen 3 blower on a Series II (L67) Supercharged engine.
