Thread: please help with spark plugs!!
Results 1 to 20 of 23
  1. #1 please help with spark plugs!!
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    I have no clue why these are so difficult, I've never had such a hard time but I can't get a good grip on the metal dust covers or the wores themselves is there a trick you guys have used?
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  2. #2 Re: please help with spark plugs!!
    pliers and pull till they rip off. Or twist and pull
  3. #3 Re: please help with spark plugs!!
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    If you have new ones to put on and you dont care about those ones, just twist and pull with pliers, worst comes to worst, pull on the plug wire, it will most likely rip out, but I found once the wire was off I could easily get the boot off the plug.
  4. #4 Re: please help with spark plugs!!
    The Boss Iceman6669's Avatar
    Jun 2011
    Dont they actually sell a spark plug wire puller??? It is a wrench like deal that grips it and should not rip it?
    2011 F-150 Yote powered
  5. #5 Re: please help with spark plugs!!
    the plug wire has to come off first.
  6. #6 Re: please help with spark plugs!!
    Quote Originally Posted by Iceman6669 View Post
    Yeah i have one it sucks i just pull out the channel locks or needle nose.
  7. #7 Re: please help with spark plugs!!
    Jun 2011
    Oh well ok then... I have never tried using them.. I did not really have too hard of a time getting mine off when I did my plugs... Just pulled like H*ll on it.
  8. #8 Re: please help with spark plugs!!
    St. Louis
    I own a pair of the spark plug wire pliers. They do work if you can get it on them. But for the GP I just twist the boot and pull at the same time and off they come.
  9. #9 Re: please help with spark plugs!!
    Oct 2011
    Michigan
    Yeah I know to twist and pull, no I do not have any new wires I'm gonna try the channel lock thing I just never had it be this difficult before
  10. #10 Re: please help with spark plugs!!
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Get new wires your car will . Use Dielectrical grease and removal will be easier next time.
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  11. #11 Re: please help with spark plugs!!
    Oct 2008
    IL
    Oh and ur talking about the metal covers those do blow
  12. #12 Re: please help with spark plugs!!
    Jan 2012
    Pennsylvania
    what ever you do make sure you keep the metal covers. They do keep the plug wire from melting next to the headers. I bought and tried to use one of those plastic plier pullers and they sucked. When you do get them off make sure to use the grease like the above thread mentioned. Don't be afraid to put a liberal amount in there.
  13. #13 Re: please help with spark plugs!!
    Those heat shields can cause a lot of problems with misfires. I threw mine in the trash and haven't had any problems with my headers.
  14. #14 Re: please help with spark plugs!!
    new york
    heat shields are garbage??
  15. #15 Re: please help with spark plugs!!
    On these cars they are.
    Only thing you should be worried about keeping are the metal boot covers.
    And honestly, I don't even have those, just route your plug wires intelligently and you won't have any issues melting/burning wires and/or misfires.
    I run Autolite 606 plugs gapped at .050"...with MSD wires...they have bendable plug boots so I can turn them away from the manifold primary on each cylinder. Easy peasy.
    Ohio
    I use the plug wire socks. Same material that the header wrap is. You have to manipulate them abit but they make for a clean look.
  17. #17 Re: please help with spark plugs!!
    new york
    i dont have headers so i should be ok
  18. #18 Re: please help with spark plugs!!
    Quote Originally Posted by kawasakidrivinghick View Post
    I don't have headers on my car either.
    My point is the factory manifolds are fine without heat shields and the metal plug boots regardless.
  19. #19 Re: please help with spark plugs!!
    Oct 2011
    Michigan
    my problem is i cant get a good grip on the metal cover, i think somethings wrong with my car it should not be this difficult
  20. #20 Re: please help with spark plugs!!
    It's easy. Vice grips on the metal plug cover. Pry against valve cover.
    Off they come.
  1. spark plugs
    By samuelcb409 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 09:44 PM
  2. Spark Plugs?
    By gahris in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-03-2010, 03:13 PM
  3. 5.3L V8 Spark Plugs
    By 06usafgxp in forum General Tech Discussion
    Last Post: 01-29-2010, 09:23 PM
  4. spark plugs
    By silverstreak in forum General Tech Discussion
    Last Post: 08-01-2009, 06:09 PM
  5. Spark plugs
    By Chleby in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-16-2009, 10:43 PM
